Installation of Deka EXT12 12V AGM Battery - Insight Central: Honda Insight Forum
Old 01-30-2005, 10:47 AM   #1 (permalink)
Default Installation of Deka EXT12 12V AGM Battery
With the death of my stock, 4 year old Honda 12V battery, I decided I would follow a few others here and install a battery better designed and sized for the application.
On the recommendations of my "battery guy" (I'm at the battery dealer about once a week) I chose the Deka EXT12. This is a 12V (obviously) AGM rated at 180 CA and designed to handle constant float charging. Being a sealed battery, it could be installed in any direction and will not gas or vent. Also, it will not dry out nor require the addition of water a regular flooded battery needs.
Because of the massive size difference, I fabricated an inner battery tray:
The tray is made of 4MM steel, two long bolts and two wingnuts. Excuse the slightly messy welding as I was having wire feed speeds (clogged tip, store was closed). A quick shot of generic aluminium paint matches the aluminium of the Insight.
Fitting the tray in the stock battery tray:
The stock battery tray is not exactly square, and it has raised sections near the bottom. So unfortunately it require some grinding to fit my tray in the car's. This ruined the paint around the edges, so I will have to repaint when the weather turns warm. Note the two drilled holes to bolt the tray in place. I could have gotten by with using some of the holes predrilled in the bottom of the battery tray, but I did not want to bother removing the tray to locate the holes on my tray adapter.
And the finished product:
I had to fabricate two 6" cables to adapt the screw type lugs on the battery with the post type the Insight is expecting. I'm not sure why I just didn't make the ground cable from scratch, but I will do so when the temperature outside increases past freezing.
Overall, the battery works great. It cranks over the car without trouble (it has been cold enough these past few days that 90% of my morning starts have been on the 12V battery).
48V Custom Aluminum Scooter
Old 01-31-2005, 12:51 AM   #2 (permalink)
Kevin Dougherty's Avatar
SWEET!! This is the smallest battery that I've ever seen fitted into an Insight. What is the weight and cost? How long will it run a full load (lights wiper, radio, fans, etc. ) in autostop?
kevin
Old 01-31-2005, 10:30 AM   #3 (permalink)
I did not actually weigh it, but my guess is a little less then 10 LBs.
Cost was $60 for me, which is the wholesale cost. I would expect retail to be $99.
As for the reserve capacity, the car is powered by the DC-DC converter 99% of the time when it is on, even in idle stop. So the size of the 12V battery is not critical.
Old 02-01-2005, 11:36 PM   #4 (permalink)
Aaron,
Deka has a good reputation in the large deep-cycle battery world, and I didn't realize they made batteries this small. Your installation took a bit of time and work, and I can't help wonder how much weight your new non-aluminum box added to your ultra-light battery...
Nice to see custom mods. Do you plan to add a thin insulator to keep the steel off the aluminum? Cheers, JoeS.
2002 Silver MT, MIMA, FAS, hand throttle, lmpg 77.7
2006 Red MT, lmpg 73.2
1967 Saab96V4 Original Owner
Two Corbin Sparrow EVs
1965 Saab EV Conversion
2012 Mitsubishi iMiEV
Dodge Ram (small) pickup EV
JoeMultihuller is offline   Reply With Quote
Old 02-02-2005, 10:31 AM   #5 (permalink)
You're right, I should have weighed the steel. But I would have to guess that it is 5 LBs or less. It's very light gauge, and weight was a concern. Unfortunately, I do not have the equipment necessary to weld aluminium.
As for corrosion, I plan to put a rubber insulator between the "adapter" and battery box when I remove the "adapter" for a repaint in the spring. I will also weigh it at that time.
