Yesterday I checked the 12v battery level (key in ACC ON, but engine off) and it read 11.5v "low". ( I also tried to check the ford focus battery , but it would not read that battery at all.
) On the Insight, this is the original 12v battery. Honda dealership said 12v was fine back in December, but since then the car experienced stalling/ no start problems and the IMA battery and BCM-MCM have been replaced. Because there are 634 "12v Battery" postings (which I scanned) I would like to ask these questions:
1. Is 11.5 v at rest low enough for concern?
2. If it is too low, can the battery simply be recharged, or is replacement a better idea?
3. If replacement is the best plan, is the Civic battery the 12v of choice? Would an Autozone, Goodyear or WalMart 12V serve well?
I'm hoping this is something that can wait, especially since I do not want to visit the dealership again so soon after all this IMA replacement hoopla. And the car is running great now. However if driving w/ a low 12 volt would somehow compromise my new IMA battery or hurt some other crucial component, then I will do the right thing, right away.
Thank-you for your advice.
