Originally Posted by Roger Crier
Back to this maximum readout thing...I get that the metric display can display better figures than 150 mpg..... but is there anyone who has a really long downhill road which they can start off on and get a figure on the metric display that is better than 1.5 litres per 100km ...could they then switch to non metric display to see what gets displayed? It should read 156mpg at least. If it doesn't then anyone who gets up to these heady figures is going to have to get used to running on metric.
The metric display which is what the car uses to figure the Fuel Economy ... The metric side goes down to 0.1 Liters of Gasoline used in 100 km ... which means if you can get this low you would see the equivalent of ~2,352 miles per gallon at 0.1 L / 100 kM.
The MPG / english side of the display will not display anything above 150MPG... so if you are getting 1.4 L / 100 kM you will only see 150 MPG on the english display even though you are actually getting ~168MPG.... The Insight calculates and stores the fuel economy on the metric side... and does a conversion to display the MPG / english side.... so the LMPG will be as accurate as the Metric Side is - the limits of the conversion to MPG / english.... even if the MPG english side does not display it like the metric side does.
I do not know what the resolution / accuracy limit of the computer system is... meaning does the car keep track just down to 0.1 L / 100 kM or does it keep track lower down to something like 0.01 L / 100 kM but the metric display only goes down to 0.1 L / 100 kM?
because serious Insight PHEV'S are becoming a reality as we speak so we need to know this stuff.
I doubt even a PHEV Insight will need to worry about Fuel Economy better than 0.1 L / 100 kM which is equal to about 2,352 MPG.... Although as you said... to see the benefit beyond 150 MPG the driver would have to leave MPG behind and get used to the metric....
The metric display has jumps though for instance 0.1 L / 100 kM = ~ 2,352 MPG ... but 0.2 L / 100 kM = ~1,176 MPG... the Insight will not display even on the metric side any value between 0.1 and 0.2 so you would not know where you are between 1,176MPG and 2,352 MPG.
oh no... EVIL Metric System... U.S. must fight this standard with everything we have
