Lifetime MPG jump. WHY?
I'm the original owner of "00 #2360. For years I "complained" about my low lmpg which has stayed at around 51.9.
I went to this group, then to the "other one," for assistance; followed all suggestions to modify driving habits, increase
tire inflation, etc., etc. Eventually, after warning light stayed lit, had the battery, BCM, ECM replaced Dec. '07 (warranty)
at 37 K (yes, low mileage) Soon after, I began to have surges at about 30 mph; becoming more frequent.
I read that EGR can require cleaning/replacement to eliminate this problem.
I reasoned I should bypass the cleaning maneuver, go directly to replacement, and did so (with photo-instructions
by David Judd.com)
Mirabile. Surging has stopped.
Even better ! ! !. After resetting a trip meter, I began noticing a big increase in mpg. Now, as of putting > 250 mi on
the Insight since EGR replacement, my mpg has improved to 57.8. This has happened while driving over the same-old routes,
without changing driver or driver-habits. (Mixed city/freeway/ 800 ft altitude climbs, descents on return route)
If this is, as I think it must be, because of something inherent in the function of the EGR, I wonder why it hasn't been
reported before. Quite the opposite. Others have remarked that, although surging has been successfully eliminated, there
hasn't been a change in mpg. Well, it doesn't seem so for me, and my Insight.
While 250 mi may not be a real "test" of lasting improvement, I give this "preliminary" happy report of a positive upswing in lmpg
after a "lifetime" of low-end mpg.
