There are several ways to disable Auto Stop. The easiest one (and you can change when you want) is to just put the climate control on Auto with the A/C on (Econ set to off)...This will keep the car idling because the A/C compressor will remain in use. It will also use more gas
To disable Auto Stop at all times there are two other ways:
1) Disconnect the temp sensor directly behind the front bumper. However, this sensor is also used to determine outside temp on cold mornings to determine if the IMA should start the car or if the typical starter motor will so perhaps a bad idea. Plus, you would not get AutoStop in any other traffic conditions as well.
2) Crimp the vacuum line to the brake sensor. I'm talking about the sensor used by the IMA to determine if the cars needs to be restarted while in Auto Stop due to vacuum loss. Crimping that line only going to the sensor would stop the car from going into AutoStop to begin with. However, messing around in this area is can be dangerous if you don't know what to crimp or where the sensor is. Plus,you would not get AutoStop in any other traffic conditions as well.
I don't think that there is any noticeable longterm damage being caused by AutoStop in bumper to bumper traffic. These engines are designed for over 200,000 miles. In fact, I created a mod to allow for even more Auto Stop in bumper to bumper traffic. It does this all automatically:
http://www.insightcentral.net/commun...php?f=4&t=7513
