"Not in this lifetime" - Insight Central: Honda Insight Forum
Old 09-02-2008, 09:13 AM   #1 (permalink)
Default "Not in this lifetime"
How do you reset LMPG?
# 772, 2000-04 5MT AC, SS Metallic
---- LMPG, 3ed Owner @ 135K
RE92's 50 psi
IMA Batt & Invert @ 123K
Next: MIMA and TPS damping
gas_burner is offline   Reply With Quote
Old 09-02-2008, 11:44 AM   #2 (permalink)
Default Re: "Not in this lifetime"
Doing a search for "reset lmpg" brought up this....
Resetting the Lifetime Fuel Mileage Display
by Motty82 on Mon Mar 31, 2003 12:01 am
Macwarrior,
I too bought my Insight used and wanted the display to show only my achievements.
To reset the Lifetime Fuel Mileage display,
1. Turn the ignition switch to ON (II).
- If the engine is running, put the transmission in neutral and set the parking brake.
2. Press the Trip button to display the odometer. Then press and hold the Trip button until the Lifetime Fuel Mileage Display starts to blink (approximately 5 seconds).
3. Release the Trip button, and press it again while the display is blinking. (Hold it until the display clears to dashes.
Your Lifetime Fuel Mileage Display is reset at this point.
~Martin
2000 Silver 5 spd
Motty82
Power Driver
ICQYIM
markw is offline   Reply With Quote
Old 09-04-2008, 12:26 PM   #3 (permalink)
bfivelover's Avatar
What about when you do something like get your car inspected, which I did today. They need to know how many miles are on the car. Are the lifetime miles still on the display somewhere?
Vegan, Silver Insight totaled at 233,000 miles, Blue Insight at 188,000 miles, cat needs replaced, IMA also
bfivelover is offline   Reply With Quote
Old 09-04-2008, 03:13 PM   #4 (permalink)
It doesn't reset the odometer, just the LMPG.
2006 MT
MIMA w/FAS module
various mods to driver
Old 09-04-2008, 05:41 PM   #5 (permalink)
AFAIK once erased the previous LMPG value is but a memory.
02 5spd, 130k+Miles
