Anyone tried these products for improved MPG? - Insight Central: Honda Insight Forum
Old 12-19-2011, 11:16 AM   #1 (permalink)
Question Anyone tried these products for improved MPG?
I found both of these on ebay:
First, this "THROTTLE SMOOTHING CIRCUIT": HONDA INSIGHT THROTTLE SMOOTHING CIRCUIT- INCREASE MPG! | eBay
and from the same seller this "REGENERATIVE BRAKING CIRCUIT": HONDA INSIGHT REGENERATIVE BRAKING CIRCUIT ! | eBay
Has anyone tried either of these? Are the claims realistic? Any drawbacks? Thanks
00 5-speed, Citrus 168k
yogaguy is offline   Reply With Quote
Old 12-19-2011, 11:20 AM   #2 (permalink)
The TPS mod helps some people stay in lean burn. Other people don't like the "delayed" feeling it gives the throttle.
The clutch switch mod, aka Calpod switch enables you to disable assist/regen at will.
Lots of information here on both. If you don't want to pay eBay prices, both can be done for a few dollars.
Old 12-19-2011, 04:47 PM   #3 (permalink)
Lean Burn = Happiness
jeff652's Avatar
I have a TPS smoothing circuit for sale. Brand new never installed. I purchased it from that fine gentleman on eBay then decided I did not need it.
PM me if interested.
Thanks
Best Tank: 90.2MPG over 918.7 miles 070MCM/030BCM, No MIMA. Details: My Commute MPGs
HybridAutomotive.com (No, not gas electric - the other kind of Hybrid)
Old 12-19-2011, 05:23 PM   #4 (permalink)
joecvt's Avatar
The second eBay item listed by the OP is not the Calpod assist / regen mod. It is basically acts like a brake pedal switch. It is hooked up with the brake pedal switch (instead of the clutch pedal).... It allows for full regen (limited by IMA) just like you pressed your foot on the brake pedal.
This mod is silly (IMO) because if you lightly press on the brake pedal you get the same thing as this mod and it will save you $28.00 plus installation time.
It is easier to adjust the standard brake light switch that is already in place so that switch contact is made before the friction brakes engage (which I believe most Insights are already adjusted correctly).
Using your foot on the brake pedal is more natural for the same amount of regen compared to pressing in on a momentary switch.
Waste of money IMO.
No other mods performed yet
2003 CVT Blue Insight
Low Speed Auto Stop (LSAS)
Not registered yet
Old 12-19-2011, 07:52 PM   #5 (permalink)
Ahh, guess I should have looked instead of assuming. But yes I agree, you can do the same thing with your foot long before you ever engage the physical brakes.
Old 12-20-2011, 09:21 AM   #6 (permalink)
racer26's Avatar
*cringe*
I developed a TPS circuit that I shared with everyone here months ago, that even in its most complex form which I got asked for in PMs, with a variable resistor to range cutoff frequency from 0.15Hz to 1.5kHz, and a footswitch controlled 12V relay, has a BOM cost of like $13 and 20 minutes for assembly.
The idea behind it was the footswitch goes where the 'dead mans pedal' should be. Accelerate as normal, and then once up to speed in 5th gear, you put your foot on the switch to engage the TPS mod and make it easier to hold LB. Best of both worlds.
Mods:
CARD switch
John Wayland's Shoebox Sub
Future mods:
Plug-n-Play MIMA?
Economy data miner
Old 12-31-2011, 01:40 AM   #7 (permalink)
RedJellyBean's Avatar
It's very easy to source the parts for the Calpod clutch switch mod yourself. Installing it is another matter, I hope you're good at soldering in a confined space, upside down, with no light!
The TPS smoothing circuit is the better "deal" because it comes pre-made and apparently the seller is also including support and instructions for exact installation. True, it's just like $2.50 worth of parts, but the time involved in getting them together, as well as the time spent digging online looking for exactly where to splice at the wiring harness, and then not being sure about certain things... the value is definitely there for some who don't want to deal with all of that jazz.
2002 Red Honda Insect 5MT
Old 12-31-2011, 04:19 PM   #8 (permalink)
AbCaRed00's Avatar
ScotchLoc connectors is what I used to avoid soldering upside down in similar circumstances. Secured, firmly taped, and zip tied , the connection is good. Not a lot of room there.
Old 12-31-2011, 11:23 PM   #9 (permalink)
I tried the 18-22AWG Scotchloks and failed miserably, so I ended up doing the chop and splice, and shoddy solder. Definitely not one of my proudest moments. Good to hear that the Scotchlok worked for you though. Where did you mount your switch? I put my switch on the shift knob, in the perfect position for my thumb to actuate IMA on and off. I feel like such a boss driving around with IMA on command, and it always gets passengers going - until I show them my Scangauge MPG average
Old 01-06-2012, 08:48 PM   #10 (permalink)
AbCaRed00's Avatar
..Good to hear that the Scotchlok worked for you though.
So far so good, I used some small needle nose vise grips to snap the scotchlocs down; not sure if the tape was required but I didn't want to do that part again soon.
I don't have the exact switch you do yet but had to install cruise control with the same connections at the brake switch and also adding a clutch switch for that system. I'm considering the smoothing circuit might be something I'd use with the Rostra cruise control on long trips and would likely mount a switch in one of the three blanks aside the steering column.
