Armin, If I recall correctly, you make an estimate of the required charge and set the charge timer accordingly?
Peter, As far as I know, Armin is the only one doing a grid charge on his system, he used some 120VAC to 24VDC power supplies in series to get the voltage, and made a simple constant current regulator to control the charge rate. Not sure where he tied in, but a quick look at the electrical manual should answer that one.
I put an anderson connector right at the rear of the IMA box for the tie in to the pack.
A photo
http://www.99mpg.com/ProjectCars/TheBes ... ite1.jpg,0
I had to use bigger wires, as I am feeding 16.5A to the pack while boosting, and soon with V-Boost, I hope to get up to 25A.
