One big plus is that slow moving traffic (< 10 mph) is not a problem as I can charge the batteries. In sections of my morning and evening commute, slow moving traffic used to to drain the battery and kill the mpg. With a cold engine and de-misters on, the auto stop wouldn't kick in either. The best time to charge the batteries.
Queries
1. I have decided I am not going to use more than one click of assist as I am trying to become a high-miler. Is this a good strategy to preserve batteries ?
2. What is the best SOC to leave the battery at? 60/70/?/100%?
Queries
1) Yes as a general rule lower drain is better for the batteries.
2) ~ 70% but you won't know where that is unless you have an OBDIIC&C gauge.
Feedback from the longer term owners would be good especially those who have upgraded to the newer software.
Gives me plenty of headroom for regen braking, and plenty of SOC in case I really need to get on it for some reason .
However, that's a bit simplistic. I actually try to AVERAGE that, but at one point in my commute I usually hit 70-75% (actually 72% is the cap with the MaxIMA battery, I haven't actually seen 75% in forever due to the computer's lack of ability at counting the higher AH cells), but by the time I get to work, I'll be more like 45%.
that slow moving traffic kill the mpg.
Hi aandu,
I took it on a longer trip today,and it's similar to what your talking about. got caught in traffic for a while still I got 54 mpg. The best I got that route was 60 mpg And milking it no traffic and just few lights. Part city highest 40 mph.
Why do the Toyota prius get 52 mpg city? Because it's use the E.M at low speed,in first gear you get about 10-15 mpg for a few second.
Here how you can have all. "How to use 80% -90% of battery pack safely"
Objective: Save/ build your SOC for future Electric motor low stop and go traffic.
How do you get there? Morning (Use assist as below) after it drop to 40% (weak part of driving) while driving concentrate using coasting in neutral or gliding (its your cheat) you should get in the 45-50 mpg range your base. after you hit low 40% SOC it's will start charging 4 bars, it's will now be harder to keep the mpg up but try harder as it make you better.as you come to a stop light use regen 1 click before you press the brake to stop but turn it off a few feet to collect auto stop. what you did was escape 100-75% Regen (heats the battery) and as you leave a stop light as soon as assist comes on turn it off after 1 gear or 2 gear (19-15 mpg) every time.(it's all needed as it's will bleed away. This is what I was talking about Pete, but you right it's covered)
After about SOC 60+ the back ground charging stop, continue slow charging. ( best part of driving, aggressive take off) because you can now click Regen twice or 3 times after takeoff as the momentum/weight will get back the assist that you used.this 4-8 bar of Regen as you glide back to better your mpg and Go on to filling your battery up to 80% to 90% full. doing it this way Its will not over heating it. I can touch mine and it's barely warm. After it's full.
Use 1 click Regen after a auto stop, as it prevent regen or assist when stopping and take off and keep the pack full till needed.
Stop and go and parking lot ,low speed 10-15 mpg is where The E.M can use this full pack.
Use the auto stop enable, so you will have to start the car moving or auto stop disable but you will have to click it off before stopping in EV mode.hold on to your base 55-60 mpg.done right you will.
So basically you gave up 75-100 regen and got
80-90% SOC in return. And a longer battery life and 60-70 mpg beating the pruis by 20 mpg. Yea.
Yesterday trip waikiki around diamond head kahala, out to Hawaii-Kai later back. Yes I coming to a stop. LOL the mini MIMA box and years of mpg driving experience, and torque mods makes a huge difference. before it's was wasted assist that need too be replace many times.
If you have a 03 hch your software was detuned to extend battery life, it's why Honda lost. this will get back some control, mine I refuse the update.
If you want to build a shifter mount, a small L shape, a 45% corner angle piece and a small bolt to hold it together and 4 screw and epoxy.
Very normal, my thumb mount kill switch and thumb. Car very fun to drive
Still working on balancing torque vs E.v.just about perfect got both. As too much torque the Ev motor Takes a longer time to get up to speed, need the torque mod to the max as I carrying around 250 lb comfort stuff got a special car 1 cin 12 v.or complete solar very low amp freezer 18 below 0 inside.
Haven't got the long hold assist tone down mode figure out consistence yet, the few times I got in I couldn't get out, most of the time anything longer that 4 second is full assist. And 2 times I got in was weaker didn't test it out much but took many tries to get out. The before update it was a 1 click and a medium click together. The newer software is just a single 1 click 4 second not more than 10 right?
The rest all works.
Battery handicap mode ? "long assist click" is working fine, it can't be tested or seen parked. I was trying for a auto disable mode when you click cancel medium to get a visual lower rpm rising parked but was getting kick out of battery handicap mode or lost in medium long click " cruze control"
They isnt that option in that mode. So all on menu working fine.
We have three buttons and three lengths of button presses.
<0.5s = Short press
>0.5s & <4s = Medium press
>4s = Long press
Each button has the following functions.
Assist (Right) Button [Red Led]
Short press = Increment Assist Level or Decrement Regen level (As now) (Assist has 4 steps/clicks) 25,50,75,100%
Medium press = Max Assist (As now)
Long press = Toggle Assist Protect Mode. Limits any future Assist request to ~12A
Regen (Left) Button [Green Led]
Short press = Increment Regen Level or Decrement Assist level (As now) (Regen has 5 steps/clicks) 0,25,50,75,100% The first click is the regen balancing mode.
Medium press = Max Regen (As now)
Long press = Toggle Regen Protect Mode. Limits any future Regen request to ~6A
Cancel (Middle) Button
Short press = Cancel any Manual Assist/Regen (As now)
Medium press = Toggle AutoCancel Assist/Regen <5mph Mode (As now) Default is ON so you can't command assist/regen when stopped on program run after software update.
Long press = Activate Cruise Control Mode
Note the Assist/Regen current limit mode restricts all Assist or Regen, wether commanded by the car or by you.
Cruise Control.
Cruise is activated by a long press on the Cancel button.
The initial target/cruise speed is the speed the vehicle is moving when you active it.
Cruise mode changes the function of the assist/regen buttons.
Up Button short click increases Cruise target speed by one unit.
Down Button short click decreases Cruise target speed by one unit.
Cruise mode can be cancelled by a short click of the cancel button.
Cruise mode ramps assist up and down to maintain the target speed.
Cruise mode can also operate with the battery protect assist limit.
Cruise does not use regen to control over speed, you are better off just letting your foot off the throttle.
Thank Pete, all working well. they have this saying make use off it's finer points, because it's start so effortfully, the kill switch was one. Add this, on a stoplight, a cvt all you have to do is click assist fast 1-2-3 about a click every two second, and just lead the take off with 10% of trottle to just shift throught the gear, it pull strongly 'or blasts away on 90% of electric power, and that about 6 secound and your about 35 mpg heading to 40. It's so cool, love it,this will hold your base mpg.
You can do this stoplight after stoplight, the cvt keep the Ev right in the proper
Gear it's just one big pull to 40 mph, standard cars stop or stand still to shift And they wonder why that car isn't making any noise While they trucks are sucking up a hold bunch of air in each gear.
the sliding mph Gage start of at 3 bars and about the 2 click it races across 40 mpg in E.M mode.I don't even have to use 100% 4 click.
So if I use this in the city, I have to give up something, so I give up the worse which is E.V 3 click or 75% asist mode in long parks at 15-20 mph that eats the most of my SOC. Instead I can bump forward it and coast.
Car so fun driving, the 03 without any update is totally diffrents, I can charge to 100%, which I do And I can hold it above 75 % all day even without using full braking regen.
The first click of assist in parking lots is cool and it's use so little of the SOC
It's will not even drop a bar for a very long time, 2 click about twice as fast
About 1 bar Dropping every 1/2 minute, 3 click faster,
If you got a Honda civic hybrid get this control box, total fun
