Pete, while your on it, just finer tuning.on the first click disable regen and asist and abc mode.
I use it after filling my SOC, for saving for parking lots assist .
I wish that it would remember that mode after auto stop. Because after saving my SOC and with too many stops and go in the city even after I click it again on I lose a few SOC for a few second over and over, as you can't turn it back *on right away. Getting back SOC at low speed does affect mpg, coasting is better.
basically *city corner to corner you don't need any assist Manuel or stock. Just concentrate on staying in the better mpg zone and coasting or gliding for distance with no *SOC lost that has to replaced gives better results. it's a important mode.
Is they a way to remember it on if we wanted to after auto stop?* a option? or maybe even over ridden manually would kick it off.
What about 1 click assist is no stock assist at all, and its remembered after auto stop. 2 click over ride this back to 1 click assist 2 click,3 click, etc?
And even if auto cancel mode has a time limit or distance use once it's turns off?
Auto cancel mode we need have the manual assist off idle. but later you have to turn it off, same as 1 click Regen or the car wont start after it some how does auto-stop. Can see it might be problematic.
Here my setup.
http://www.insightcentral.net/forums...057-photo.html
