New hybrid system from Honda(Finally) - Page 2 - Insight Central: Honda Insight Forum
Old 11-01-2012, 12:48 AM   #11 (permalink)
Huh? What are they talking about here?
From what I could tell they are going to a full hybrid system that can run on gas only, electric only, or a combination of both.
Edit: Ah, never mind I catch your meaning. I agree that I don't see a problem with my idle stop, seems pretty smooth to me.
Old 11-01-2012, 08:25 AM   #12 (permalink)
samwichse's Avatar
The I2 and CR-Z have had many complaints about jerkiness on take off from idle stop to 5mph.
-OBDIIC&C
-IMAC&C
-Lower grill block
Old 11-01-2012, 05:51 PM   #13 (permalink)
That has more to do with the CVT though, doesn't it?
503-730-8786
info@bumblebeebatteries.com
Old 11-01-2012, 06:21 PM   #14 (permalink)
samwichse's Avatar
Right, and the new hybrid system by Honda supposedly does away with the old metal band CVT and goes to an electric countertorque system like Toyota uses in the Prius. Hence it has a smoother electric-gas transition.
Sam
-OBDIIC&C
-IMAC&C
-Lower grill block
Old 11-01-2012, 11:33 PM   #15 (permalink)
Rush's Avatar
Is the 'electric countertorque system' the Planetary Gear Set?
Here is a great visual that shows the interaction between the gas and electric motor
http://eahart.com/prius/psd/
Rush
www.TucsonEV.com
Tucson AZ
Old 12-06-2012, 07:39 PM   #16 (permalink)
No. If Honda copied Prius directly they'd probably get sued, so they have the Atkinson engine and two motor/generators but not the gear set. Instead they have a direct drive system from the motor to the wheels (with clutches to introduce an extra "boost" from the engine as needed).
This news merely tells me I need to go stock-up on Insights because future Honda hybrids won't be worth buying. They'll be like Priuses (which I find dull & disconnected). Doubt we'll see anymore 70mpg wondercars either, like the insight or VW's diesel Lupo. Manufacturers seem satisfied with just 45-50 maximum.
both blue and silver,
Old 12-06-2012, 09:28 PM   #17 (permalink)
The dull and disconnected feeling of the Prius is a Toyota thing, not a hybrid or it's drivetrain thing.
Honda has always been very good at making fun to drive cars. I'm sure the offerings with the new hybrid system won't be any different.
503-730-8786
Old 12-06-2012, 09:42 PM   #18 (permalink)
The only other Toyota I've driven was an Echo (same body as the original Prius) and it didn't have that dull or disconnected feeling. In fact it was quite a fun car to drive. BUT the computer-driven prius 1, 2, and 3 felt like I was not in charge. The engine would randomly rev high for no apparent reason, or shutoff for no apparent reason. It was weird.
I prefer the IMA. It's an engine. With motor assist. It makes sense to me what it is doing, and let's me be in charge, so I can get really high MPG or sacrifice MPG for power/fun. It sounds like the new Atinson/motor/generator deal will take that away & be a computer-driven car (like prius).
Old 12-06-2012, 09:55 PM   #19 (permalink)
Ah, I see. I agree. I like IMA because of its "KISS" principles.
I have to admit that Toyota's system is pretty ingenious though.
503-730-8786
