LPG conversion on a HCH1 - Insight Central: Honda Insight Forum
Wheel & Tire Center
Old 12-24-2012, 08:23 AM   #1 (permalink)
Default LPG conversion on a HCH1
How suitable is the HCH1 for lpg conversion?
My other car, a Suzuki Ignis which has had LPG conversion done on it.
Wondering what things I should consider when trying to LPG convert the Civic Hybrid.
I can think of :
* Auto Stop- When car starts back from auto stop, if engine is warm it should start directly on LPG instead of on petrol and then switching to LPG.
* Lean Burn- Not sure if LPG ECU would be able to handle this.
* IMA C&C- assuming it would still work with no changes.
aandu is offline   Reply With Quote Quick reply to this message
Old 12-24-2012, 09:21 AM   #2 (permalink)
Premium Member
samwichse's Avatar
IMAC&C should work fine unless you completely change out the ECU somehow and the new one is hybrid-dumb (doesn't communicate with the MCM in back). Is this a chipping situation, or do you have a completely new ECU?
Lean burn: You're going to have to give that up, I I think.
Old 12-24-2012, 10:54 AM   #3 (permalink)
The HCH ecu remains untouched. A separate LPG ECU which acts as a slave to the HCH ECU is added. The LPG ecu would issue its own slightly modded instructions to the LPG system based on whatever the HCH ECU does.
Originally Posted by samwichse View Post
Lean burn: You're going to have to give that I I think.
I don't quite understand this line.
Old 12-24-2012, 02:05 PM   #4 (permalink)
Premium Member
samwichse's Avatar
I think I dropped the word "up" let me fix that
Doubt you'll be able to have lean burn.
If you're just piggie-backing another ecu on, I don't see why the IMAC&C wouldn't work.
Sam
Old 12-24-2012, 03:21 PM   #5 (permalink)
IMAC&C will work if the ECM and MCM remain connected via the MOTA line in the same way as standard. So it won't care about LPG or otherwise.
Pcb's/Built Units for ObdIIc&c, Imac&c, ImaBoost, Current Hacks available. Enqs to 150mpg[at]gmail.com
retepsnikrep is offline   Reply With Quote Quick reply to this message
Old 12-24-2012, 07:35 PM   #6 (permalink)
My LP gas conversion experience is limited to carburetor fed engines only. Fuel injected engines appear to require additional controls.
The LP gas conversion carburetor is a simple perforated venturi through which the vaporized LP/gas is drawn into the intake manifold. Gas flow through a vacuum switch controlled solenoid valve feeds a vaporizer/regulator which may or may not allow starting the engine on LP gas depending on its design. The vacuum switch which responds to intake manifold pressure is bypassed during start up to allow gas to flow with engine stopped. Gas flow will be cut off at Auto Stop (no vacuum) and restarting after Auto Stop will have to sequence the start up process each time.
Most LP gas converted engines will be set to run slightly rich to lessen the possibility of burning the exhaust valves. Lean burn may best be avoided or require a change in exhaust valve metallurgy such as stellite.
Hugh-Falls is offline   Reply With Quote Quick reply to this message
Old 01-04-2013, 06:44 AM   #7 (permalink)
Just had confirmation that lean burn would be possible.
The LPG ECU would mimick what the petrol ECU does. So if petrol ECU says "shutdown two cylinders", the LPG would follow suit. Or at least that's the theory!
Might be doing the conversion in the next 2-3 weeks. Shall report on how it goes.
Old 01-04-2013, 07:13 AM   #8 (permalink)
Default Lean Burn
It appears that at this point in the discussion there needs to be a definition of what constitutes "lean burn" in the specific engine under consideration.
Old 01-04-2013, 10:38 AM   #9 (permalink)
I agree. Not really sure if lean burn is activated by lower AFR to all cylinders or in addition to lower AFR, some cylinders are shut off as well.
Old 01-04-2013, 11:08 AM   #10 (permalink)
The HCH1 does not shut down any cyclinders when in lean burn, it affects all of them and is a general leaning of the mixture.
The HCH1 does shut off the valves on three of the four cylinders on the overun when the injectors are not operating. It does this to improve regen effeciency.
Random Question
