Battery not charging? brake and battery light on. - Page 2 - Insight Central: Honda Insight Forum
Wheel & Tire Center
Old 03-20-2017, 04:41 AM   #11 (permalink)
Found a post where some guy has a similar problem when hitting full assist, his brake + battery light would come on.
Well the brake light comes on because it is tied in with the battery light ground, which causes both to come on. So really this is just the battery light coming on.
My battery light also seems to come on after flooring the car, similar to him hitting full assist.
What I think may be happening is that during full assist the voltage on the IMA battery drops so much that maybe it is stopping the DC-DC converter?
What doesn't make sense is why would assist and regen still work and the IMA light not coming on?
insightbuyer is offline   Reply With Quote Quick reply to this message
Old 03-20-2017, 10:17 AM   #12 (permalink)
Lyger's Avatar
most likely you'd get a 1449 if the IMA battery was the main culprit.
if the 12V battery though was an issue then i could foresee there not being a code set, but you seem to like taking the highest road to diagnosing your problem.
2000 silver 5 speed 275k (RIP, accident casualty)
2001 blue 5 speed 300k (daily driver)
Lyger is online now   Reply With Quote Quick reply to this message
Old 03-20-2017, 11:17 AM   #13 (permalink)
Rainsux's Avatar
We are all just speculating until we get a report that the 12V has passed a load test, and that the ground straps are intact. There is no point in discussing it farther at this point. We can move on to the harder stuff after this easy stuff is either confirmed or eliminated.
I recently had some similar weirdness that I attributed to leaving the radio on for a few hours. Charging the 12V "fixed" it for a few days. Then it did it again (my wife was driving it-not good) so I had the 12V load tested. It failed, even though at the moment the car was working fine. When the voltage drops to the point that the 12V can't properly power the computers all kinds of strange stuff happens.
You can't assume that your 12V and ground straps are good. Just make sure that they either ARE the problem or NOT the problem before you do anything else.
Sam
2000 Citrus
Custom Turbocharger System
MIMA #150
BumbleBee Battery
OBDIIC&C Gauge
NM license plate KERS
Alpine Stereo
GAZ rear shocks
Old 03-20-2017, 02:37 PM   #14 (permalink)
S Keith's Avatar
Originally Posted by insightbuyer View Post
I'd like to add about this that this past summer I fixed a completely separated ground strap and the others felt sturdy.
This is why I'm going to rule off a bad 12 volt battery, because the battery held up for a while.
I will also use my grid charger and discharger, and run a cycle or two with it as I don't do this often at all anymore.
My IMA battery is getting old as I believe it was replaced once, and before I had the grid charger I was getting error codes a few years back. So the battery is not exactly in the best condition and probably needs to be grid charged a few cycles.
"the others felt sturdy" is completely inconclusive. That's like looking at a tire from 20 feet away and concluding it's at the proper tire pressure.
It's never a bad idea to hit an IMA battery with a grid charge if it hasn't been done in awhile.
'05 G1 CVT w/192K mi as of 7/2016; '02 G1 CVT w/182K mi as of 7/2016 (P1449 HR pack); '06 HCH2 #1 w/145K mi as of 7/2016 (SOLD!), '06 HCH2 #2 w/223k mi as of 2/2016 (SOLD!); '03 Prius w/166K mi - Pack rebuilt with Gen2 modules; '08 Prius w/135k mi as of 7/2016; '07 Prius w/185k mi as of 7/2016
Old 03-20-2017, 08:21 PM   #15 (permalink)
Yes you are correct that feeling sturdy doesn't tell you the whole picture. When I replaced my last one I did a lot of testing with my ohms meter to see how well the electricity was flowing through the bolt.
You see the ground straps are clamped down with the bolt, and the ground strap lays partly on the painted surface of the car, electric won't pass through there. It has to pass into the bolt from the top of the ground strap connector.
What I found is that the bolt rusts up a little and doesn't really allow electric to pass through it. I should pull the other and clean them up like the one I replaced, and sand down the bolt to make sure it is making contact.
The thing with the ground straps is that my car ran fine with just two of them, and then I replaced the third recently. So it is hard to really think it could be the ground straps because of just replacing one, while the car ran fine without that one.
Old 03-20-2017, 08:28 PM   #16 (permalink)
My car seems normal for the most part, however, when I floor the car, almost always on the highway, the battery and brake light sometimes come on.
This was reported in another post from someone who when having full assist the battery and brake light come on. He said just one bar below full assist is fine, but once he hits full assist his brake light comes on.
In the past this light would usually shut off after a few minutes, but now it takes shutting the car off. So it does seem to have gotten worse.
I can actually just turn the car off while on the highway, and turn it back on and put it into gear, and then the battery light is off and the car is fine.
My thinking is this has to do with the IMA battery voltage possibly going really low and shutting off the DC-DC converter. Why else would this only happen when flooring the car at full assist?
This doesn't always happen when I floor the car and sometimes I can't make the battery light go on, and it seems to happen more at highway speeds.
Old 03-20-2017, 09:51 PM   #17 (permalink)
eq1
eq1's Avatar
1. Ground straps,
2. 12V battery,
3. failing IMA battery...
4. combination of 2 or more.
2000MT, CAN, ~168K miles
Old 03-20-2017, 10:52 PM   #18 (permalink)
Mountain driver's Avatar
++1 ^
Verify condition of all grounds. Though they may appear ok on the outside, remember they usually corrode from the inside.
Willies favorite: Load test the 12v. Autozone and the such will usually load test your 12v for no cost.
Un-noticed code? Is your ima light functional ? Should light briefly on start up.
btw: CVT ? (flooring it brings the batt and brake lights).
my 5 cents worth.
...Bob
'01 cvt, "Red Rider" , 208k, 63 lmpg, IMAC&C
'01 mt, "Silver Glider", 204k,
, MIMA
'00 Citrus,,
, 176k, MIMA,
Go Navy, or don't go
Mountain driver is offline   Reply With Quote Quick reply to this message
Random Question
