New owner, car won't start. - Insight Central: Honda Insight Forum
Wheel & Tire Center
Old 04-20-2017, 11:09 PM   #1 (permalink)
Default New owner, car won't start.
Car turns over, but will not fire up and run. Being somewhat mechanically inclined, I have checked the basics. Has fuel & spark, and tried starting fluid to rule out bad fuel, even changed the plugs and still won't fire. Going to check compression tomorrow, if that's good, where do I go next?
BecauseVTEC is offline   Reply With Quote Quick reply to this message
Old 04-21-2017, 12:57 AM   #2 (permalink)
Did the car start before you bought it? Or you bought it in this non-start condition?
Sounds like your IMA battery is dead and it's using the 12V starter. 12V could be weak. You can try load testing the 12V battery or connecting jump starter to it.
You can also check IMA battery to make sure it's connected, measure voltage, and perhaps grid charge it to acceptable range and see if it will start off IMA, like it normally does.
2004 HCH1 180k, 2001 I1 208k, tooting around bay area, CA
Old 04-21-2017, 07:25 AM   #3 (permalink)
ericbecky's Avatar
Welcome to Insight ownership.
Sounds like you are moving in the right direction.
Check the ground straps.
Feel free to call me if you want to talk through ideas.
EV Powers Hybrid Battery Service and Repair
Your Hybrid Battery Hero
Madison, WI
608-729-4082
Mobile service also available
ericbecky is offline   Reply With Quote Quick reply to this message
Old 04-21-2017, 08:23 AM   #4 (permalink)
Before leaving for work this morning, I tried a known good 12v battery from my current daily and it was basically the same. It had been just turning over slowly and every once in a while it would spin over real fast not starting of course. With the good known 12v, when I keyed on I heard a solid 3-5 clicks from the console area before turning over quickly then continuing to turn over slowly again. (Maybe IMA then 12v) still not starting.
Old 04-21-2017, 08:25 AM   #5 (permalink)
Oh, also I forgot, yes I bought it in this non-start condition.
Old 04-21-2017, 09:27 AM   #6 (permalink)
Is there a green flashing key on left of dash. It should flash when you put key in and turn it to just before start, then a second later it should go out and then it should start.
It is a security feature and may require a dealer to re-prog. Unless anyone knows a way around this.
seca turbo is offline   Reply With Quote Quick reply to this message
Old 04-21-2017, 09:32 AM   #7 (permalink)
Rainsux's Avatar
The starter won't spin if it's the immobilizer.
Make sure your ground straps are all good.
A few Insights have suffered a broken camshaft. Your compression test will answer this, but you might want to pull the valve cover and verify camshaft operation.
Did the PO have any clue as to what was wrong?
Sam
2000 Citrus
Custom Turbocharger System
MIMA #150
BumbleBee Battery
OBDIIC&C Gauge
NM license plate KERS
Alpine Stereo
GAZ rear shocks
Old 04-21-2017, 09:53 AM   #8 (permalink)
PO says he was driving it and it puffed smoke and died on him but he restarted it, drove a few more feet then died again and towed it home. I checked for milky oil from a head gasket and made sure it rolled over before buying it.
Old 04-21-2017, 11:17 AM   #9 (permalink)
Lyger's Avatar
if you're positive that you have fuel and spark, then you're luck is about up, considering what the previous owner said happened it's likely the compression test won't be good. the erratic cranking could also be pointing to something seriously wrong in the engine, like a broken cam or worse.
hope you got it for a good price.
2000 silver 5 speed 275k (RIP, accident casualty)
2001 blue 5 speed 300k (daily driver)
Lyger is offline   Reply With Quote Quick reply to this message
Old 04-21-2017, 01:20 PM   #10 (permalink)
As stated by others if you def have sparks and fuel (inc easystart sprayed into air intake) and no start then I suspect cam
Pcb's/Built Units for ObdIIc&c, Imac&c, ImaBoost, Current Hacks available. Enqs to 150mpg[at]gmail.com
Random Question
