I upgraded the ground cables - Page 2 - Insight Central: Honda Insight Forum
Old 05-18-2017, 01:47 PM   #11 (permalink)
S Keith's Avatar
Nice. Any issues with the 1/0 stiffness on all but the battery ground?
Good news is you'll never have to deal with it again as long as you stay in AZ.
'05 G1 CVT w/192K mi as of 7/2016; '02 G1 CVT w/182K mi as of 7/2016 (P1449 HR pack); '06 HCH2 #1 w/145K mi as of 7/2016 (SOLD!), '06 HCH2 #2 w/223k mi as of 2/2016 (SOLD!); '03 Prius w/166K mi - Pack rebuilt with Gen2 modules; '08 Prius w/135k mi as of 7/2016; '07 Prius w/185k mi as of 7/2016
Old 05-18-2017, 01:49 PM   #12 (permalink)
S Keith's Avatar
ground straps
Old 05-18-2017, 03:28 PM   #13 (permalink)
all grounds and electrical component locations
[/url]https://docs.google.com/spreadsheets/d/1bLUyuFXWywH0PIzTXYtT6UprBNkOtjnWh5PFKjDFylA/pubhtml?gid=119037046&single=true
Here's a mobile phone size formatted spreadsheet link showing all the grounds in the vehicle. Links pictures, and grounds distribution pdf from the repair manual. fwiw: Crisper photo's.
_________________________________
fwiw: held for a year. I repaired my broken ground cable [surprising no CEL] by retwisting and recrimping the stock cable , cleaning terminal and connection etc .... and all was ok, until it let go like a guitar string breaking one day accelerating off a light from standing start in first gear. [fwiw: still no code]
The rear motor mount was broken and the motor flexed the few remaining strands of wire by that point on the slightly shortened cable to the limit.
I got a Honda one for about $11cdn.
__________
Wondering is the 0/1 cable in the pic CCA copper coated aluminum?? [noting shiny parts in the cut view]
AbCaRed00 is offline   Reply With Quote Quick reply to this message
Old 05-19-2017, 12:29 AM   #14 (permalink)
The welding cables are surprisingly soft.
Mine are all copper.
http://www.ebay.com/itm/15-039-EXCEL...vip=true&rt=nc
tryingbe is offline   Reply With Quote Quick reply to this message
Old 05-19-2017, 07:30 AM   #15 (permalink)
That's cool, since you had the extra cable lying around. Way overkill, so no need for anybody to get excited and buy new welding cable just for this job. In normal operation the cables just pass a few amps, and even during cranking with the 12V starter, maybe 100 amps tops. I did mine with the lawn mower battery cables from the auto parts store, put a loop in them for vibration resistance, and they're doing fine 7 years later. The main problem with the original design is that the cables are too short for the amount of engine movement so the vibration constantly flexes the copper at the ends. And also the copper was exposed to corrosion.
2001 Gen 1 Insight MT w/Homebuilt Grid Charger + Expertfabricator Subwoofer + GAZ rear shocks + Bumblebee Battery
ackattacker is offline   Reply With Quote Quick reply to this message
Old 05-20-2017, 06:41 PM   #16 (permalink)
I was curious on old ground straps resistance and found 'mudders' [Thanks! btw, v. much appreciated.] technical video below:
Honda Insight G1 Ground Strap 4-Wire Resistance Measurements
Mudder's text comments here.
PLEASE HELP!!!! Error code P1644 at whits end!
Old 05-20-2017, 08:30 PM   #17 (permalink)
eq1
eq1's Avatar
That's actually a really nice video, interesting, clearly explained. Thanks to Mudder for that and to AbCaRed for digging it out...
2000MT, CAN, ~168K miles
Tags
cable, ground, upgrade
Random Question
