Check Engine Light - Page 2 - Insight Central: Honda Insight Forum
Old 03-20-2011, 01:43 PM   #11 (permalink)
Originally Posted by Ullearn View Post
I started thinking it was Shell Gasoline causing the problem since they are known for having too much water mixture in their gas (or so the small engine repair shop near my home says as it tears up lawnmowers left and right).
I hadn't heard that. I've been using almost exclusively Shell in both my cars for ages and haven't had any problems at all. Not that I think it's the absolute best gas out there, just figured it's reliable.
2006 MT
MIMA w/FAS module
various mods to driver
Old 02-10-2012, 12:02 PM   #12 (permalink)
Bumping this thread again to see if there is any common solution?
I no longer smell any gas in the car but the check engine light comes and goes and it's time for inspection. I did replace the fuel cap with the Auto Zone knock-off brand with no prevail; I remember the Honda one being pricey for a gas cap.
Ran the codes again today and beyond the P1420 I am now also seeing the P1456. I pretty much do all my repairs and curious to know how easy it would be to perform the following if needed?
Originally Posted by rajuncajun View Post
1. Loose fuel cap
2. Vapor canister saturated
3. Failed vent solenoid
4. Failed purge solenoid
#2 = Carbon-filled canister that absorbs gas fumes from the tank is saturated with fumes, presumably this means it needs replaced.
#3 and 4 are both electric valves and I believe one is between the gas tank and the carbon canister and the other between the canister and the engine. They work together to control when gasoline fumes are sent to the canister for storage, and when they are sent to the engine to be burned off.
I am going to be selling the car in the next couple months and figured I would finally fix the cause this time versus just resetting the check engine light.
Ullearn is offline   Reply With Quote
Old 02-10-2012, 03:32 PM   #13 (permalink)
AClewell's Avatar
I would bet that you have a mouse chewed or cracked hose on the top of the fuel tank. If I remember right you have to remove a pannel behind the seats to access the top of the fuel tank. The proceedure is listed somewhere on this site.
Lil Red 01 5spd 220k mi
ODBIIC&C v0.03
Clutch Switch
TPS smoothing mod
relocated inlet air temp sensor
Spats cutout mod.
03 HCH CVT 97k
AClewell is offline   Reply With Quote
