Originally Posted by trinity02
Recently helped my daughter buy an 02 Insight and just discovered the High Beams aren't working at all. When we push the turn signal lever forward, both headlights go off and no indicator lights up on the dash. I scanned the owners manual for a high beam fuse and couldn't find one. I can understand both high beams being burned out, but why no indicator light?
There are headlight fuses but they are not your problem. The fuses are 8 and 10 (15A) under the hood fuse box. According to the electronic manual (not the owners manual), the same fuse is used for high and low beams. The reason for two fuses is one is for left and one is for right. There are also two headlight relays (left and right) but they do not control the switching of low or high beams either (same story as the fuses).
Your problem is in the headlight combination switch assembly or the Red/Blue wire (pin 4), Red/White wire (pin 6) that comes out of the assembly connector.
The combination assembly has three function areas:
1) Three position knob for - all lights off, parking lights, headlights and parking lights.
2) High / low beam switch
3) Flash to pass switch
Within the switch assembly, your problem is not function 1. Your problem is either number 2 or 3 or the Red/Blue, Red/White wire that comes from the assembly connector.
You have not mentioned if you tried the flash to pass portion of the switch, if that part works, it can be narrowed down even further to number 2 function or the Red/White wire coming from the connector.
The reason why I mention the wires is because there was a recall on earlier model Insights due to headlight wires melting (wrong size or type of wire used).
The electrical manual clearly pinpoints your trouble to faulty wiring or bad combination switch. It is not the fuses or relays based on the electrical design and the fact that you say your low beams work. In this design, the positive wire is shared for high and low beams and that is the wire that goes both fuses and relays. The ground wire is toggled via the switch assembly and activates the indicator light. Since low beams work, it can not be the fuses or relays since they are shared.
Hopefully that steers you in the right direction.
Try the flash to pass switch though.
