Originally Posted by red1dr
Good point. In LB it needs to be where the richest portion of the charge is, and also not disperse the rich portion of the charge during compression??
In YourOilShop - Spark Plugs and Indexing Washers they wanted the gap facing the intake valve, but that was for a non-LB Harley engine and they also noted that many customers didn't notice a difference if their plugs were indexed or not.
True; with the everyday average engine, M/C or car, the only way you'd
know plugs were indexed would be because you knew you put them in that way; you'd never know judging by the way it would run...
But....the Insight is quite special, - because of lean burn, it needs all the
help it can get to run well, thus the indexed plugs. Using indexing
washers works much better than the silly-priced "special" plugs. And, you get to buy plugs anyplace....
