Should I skim The Flywheel??? - Insight Central: Honda Insight Forum
Old 08-22-2011, 04:48 PM   #1 (permalink)
Mark Elvin's Avatar
Default Should I skim The Flywheel???
Cant work out if I should get the spare flywheel skimmed, or if I should use this one as is. There is no appreciable ridge where the flywheel is worn.
Mark Elvin is offline   Reply With Quote
Old 08-22-2011, 04:52 PM   #2 (permalink)
According to my new Exedy clutch kit, the warranty is void if you don't resurface the flywheel, lol.
I didn't do it, surface looked fine.
Old 08-22-2011, 05:02 PM   #3 (permalink)
I've never bothered with any of mine even the 250,000 mile one looked OK.
But that was mostly motorway miles not that much gearchanging.
Old 08-24-2011, 01:52 PM   #4 (permalink)
I would do it. Those look like hot-spots on your flywheel. 6 bolts and $30 at the machine shop = peace of mind.
Mike M., Palm Harbor, FL
2000 Insight 70k, as well as:
2000 CRV, 2002 Ford F150, 1988 Toyota MR2 Supercharged (under construction)
mikemo is offline   Reply With Quote
