Manual Transmission Swap - Insight Central: Honda Insight Forum
Old 08-23-2011, 08:10 PM   #1 (permalink)
Default Manual Transmission Swap
I picked up a used transmission from a salvage yard and am going to switch it out next weekend with an acquaintance. I already have a clutch kit, but are there any other seals and gaskets I should replace when doing the swap? Please include part numbers. Thanks..
BlueFalcon is offline   Reply With Quote
Old 08-23-2011, 09:21 PM   #2 (permalink)
Here is a link I got off the forum for clutch replacement, may not speak to the seals but might be helpful getting the transmission out.
Reviving a 2000 Honda Insight "beater" - Page 12 - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com
Also some forum links:
Swapping transmission this weekend
Clutch Alignment Tool
Old 08-23-2011, 09:36 PM   #3 (permalink)
You'll probably want the seals.
91205-PL3-A01
91206-PHR-003
