TPS Replacement - Insight Central: Honda Insight Forum
Old 08-24-2011, 02:40 PM   #1 (permalink)
Default TPS Replacement
I have to to replace the TPS, on my car is there a place to get it where I don't have to buy the entire throttle body?
I looked at majestic and others and it seems like it is not sold separately?
2000 Insight - Yellow Citrus #830
Formely owned by BP
__________________________
Best 1 Way 26 Miles - 91.1MPG
Best Tank Average - 84 MPG
Dezoris is offline   Reply With Quote
Old 08-24-2011, 04:08 PM   #2 (permalink)
Lean Burn = Happiness
jeff652's Avatar
Is it the standard Honda TPS? Can you snap pic of it? If so, I have several spares and would be happy to send one for $20 - to cover shipping and a case of cold ones
Best Tank: 90.2MPG over 918.7 miles 070MCM/030BCM, No MIMA. Details: My Commute MPGs
HybridAutomotive.com (No, not gas electric - the other kind of Hybrid)
Old 08-24-2011, 06:12 PM   #3 (permalink)
I saw someone mention that it would be almost impossible to get the TPS off the throttle body, which kinda confused me. I thought it was generally an easy to replace part.
Anyone have any... Insight?
Old 08-24-2011, 06:45 PM   #4 (permalink)
I dont even see the part listed here:
2000 Honda Insight Throttle Body, 3DR DX (A/C) KA 5MT E__01
Here is the picture of the throttle body:
http://www.hondapartsnow.com/diagram...ody-456078.png
Formely owned by BP
Old 08-24-2011, 10:56 PM   #5 (permalink)
jeff652's Avatar
The TPS appears to be mounted to the TB with rivets, but they are actually breakaway 6x1.0mm bolts. Simply notch the bolt head with a hack saw and they thread right out.
After looking at my Insight the TPS is indeed the standard Honda unit. I checked my parts bin and I have at least one in there. Apparently there are a few aftermarket options also (i.e. blox).
Be sure to adjust it properly after install. They have play in them so that the voltage can be adjusted. There are several how-to's on the web for how to do this.
Old 08-24-2011, 11:03 PM   #6 (permalink)
Interesting. Thank you very much for that information.
