My turn for a P1447 - Insight Central: Honda Insight Forum
Old 09-06-2011, 10:10 PM   #1 (permalink)
Default My turn for a P1447
Two weeks straight of 110 finally did in my battery it seems, though it has been getting weak for awhile.
The car is still running fine with assist/regen, but the available battery power is miniscule (I get a positive recall at 8 bars!).
Was planning on getting one of the new grid chargers, but they are still not ready yet. Does anyone still have rental chargers available?
Once the car cools down, I'm going to try and pull the battery cable and do the relearn procedure in hopes of buying some more time.
Old 09-08-2011, 02:55 AM   #2 (permalink)
Good news! Doing the battery relearn cleared the IMA light and it has stayed off (for now, at least).
I'm curious as to the benefits (and possible dangers) of doing the battery relearn 3-4-5+ times in a row since you get several minutes of forced charge even if the battery is 'full'.
Would be sort of a poor man's trickle charger, but not sure how much energy I'd be really adding into the pack.
Old 09-08-2011, 06:41 AM   #3 (permalink)
aisbell's Avatar
I would be surprised if the battery overcharge protection is not working fully during a battery relearn procedure. So I doubt that you could damage the battery during a battery relearn procedure.
Aloha,
Art Isbell
2000 Insight A/C #559
Old 09-08-2011, 06:57 AM   #4 (permalink)
Mark Elvin's Avatar
Relearn procedure????? This is something I have missed.
2001 Aqua Marine Blue G1 Insight
80.1 LMPG
'Max regen' switch
IMA C&C (to be fitted)
ODBII C&C
126,500 miles
Better Battery Fitted 20-02-12
Mark Elvin is offline   Reply With Quote
Old 09-08-2011, 07:13 AM   #5 (permalink)
aisbell's Avatar
You're probably familiar with this but maybe not under this name.
The relearn procedure calibrates the IMA charge level measurement to reflect the current battery capacity and charge level. This occurs automatically whenever a recal occurs. You can force an eventual positive recal by disconnecting the 12 v. battery or removing the EPS fuse briefly, both of which delete the stored charge level information.
Aloha,
Art Isbell
Old 09-08-2011, 07:41 AM   #6 (permalink)
Mark Elvin's Avatar
Ah, OK. Yep, just a reset then, cool.
80.1 LMPG
'Max regen' switch
ODBII C&C
126,500 miles
Old 09-08-2011, 12:01 PM   #7 (permalink)
NorthwestIL's Avatar
Hi! Do I need to capture any information on the IMA before I unhook the 12 volt battery? Will all of the radio stored information be erased too? My IMA light came on a couple of days ago and I am worried about what I am doing to my batteries?
Thanks! Rich at richcrandall10@yahoo.com
NorthwestIL is offline   Reply With Quote
Old 09-08-2011, 02:29 PM   #8 (permalink)
I think doing back to back re-learns is a good way to get some capacity back, I don't think it will hurt anything as the charge is only 6A. Eventually it will get to a point where the car does a positive recal very quickly after the reset.
But yes, disconnecting the battery will reset your radio too.
