Originally Posted by Leeper
I had a pair of snap ring pliers but found it much easier to simply use a fine blade of a slotted screw driver at the same time put some pressure pulling the parts apart, seemed to work a lot easier for me at least. It took some monkeying around to figure it out and a bit of frustration.
OK, but how do they come apart?
If I expand the snap ring it moves out of the bearing groove, but then has no where else to go. So when released, it goes back into the bearing groove. I must be missing something obvious here. Do the ends of the snap ring catch on something? For example, do I push them into the casing groove until they catch a lip or something? In all the work I've done with cars, I've never pulled a transmission apart before so I'm not familiar with the weird ways they seem to be assembled.
It looks like the casing can be removed while the snap ring is held open, but the casing doesn't even want to budge yet.
The tough parts in my tranny repair was figuring out how to get the axles out (did not follow the manual recommending to remove the ball joints rather I simply removed the 2 19mm bolts holding on the spindle and that allowed everything to come apart far easier
Heh, me too. I took one look at the limited access to the ball joint bolt and said "Screw this".
The only issue with my big shock bolts was that they were all rusted in place. It took some serious work with a 500 FT-LB impact to get them off and they just barely made it. I'll need to replace them during assembly.
All said now the repair would be VERY easy. I had the tranny out of the car in about 45 minutes once jacked up. Good luck
I refuse to admit how long it took me to remove the transmission from the Insight. I'll say that I can have an RX-7 transmission in and out within an hour though.
Bloody front wheel drive...
