OK, thanks for all the replies. I finally went under the car to change the manual transmission fluid and take a better look for the leak. To me right away it looked like the fill plug was suspect because it looked like the fluid trail was coming from there. I did check other areas like the axle etc. but did not notice anything.
I went to remove the fill plug and as soon as I put the 17mm socket on it the damn plug started to turn. It was bascially not tightened down at all, totally loose.
I emptied the transmission fluid and a little more than a quart came out. So it looks like I was running the transmssion with about 1.1 quarts, when the fill took about 1.6 quarts. So I was running the car 1/3 low or .5 quarts low.
I wonder how bad this is on the transmission. Oh well, I just bought the car so not sure who did not tighten it down.
Do you think this bolt could have worked itself loose, the torque spec was 33ft lbs.
