Driver side window going VERY slow - Insight Central: Honda Insight Forum
Old 10-10-2011, 01:48 PM   #1 (permalink)
Default Driver side window going VERY slow
Is this a clear sign that the window motor is going out? Or is it something else? It just seems to take forever to go up sometimes.
If it matters, its a 2000 with 107k on the clock.
Thanks guys!
cah155 is offline   Reply With Quote
Old 10-10-2011, 03:26 PM   #2 (permalink)
InsightfulMeasures's Avatar
Cah155,
That sounds symptomatic to a dying power window motor. I endured about 2 years of contending with a sluggish window motor in my Insight but I finally replaced it this past weekend.
I would recommend testing the motor before replacing it, however. Here is the procedure for testing the power window motor on a '00 Insight:
1) Remove the door panel with as little bending as possible to prevent creasing or breaking it:
*diagram courtesy of hondapartsnow.com; all rights reserved
2) Disconnect the 4-pin connector (A) from the window motor.
**Shown here: 4-pin connector (A)**
3) Test the motor in each direction by connecting battery power and ground according to the table. When the motor stops running, disconnect one lead immediately.
4) If the motor does not run or fails to run smoothly, replace it.
**Shown here: Test the motor in each direction by connecting battery power and ground according to the table (when the motor stops running, disconnect one lead immediately)**
-Pulsar Test-
1) Connect the test leads of an analog ohmmeter to the No. 3 and No. 4 terminals.
2) Run the motor by connecting power and ground to the No. 1 and No. 2 terminals. The ohmmeter needle should move back and forth alternately.
3) If it does not, replace the power window motor.
"It's actually very difficult to make something both simple and good" -Paul Simon
InsightfulMeasures is offline   Reply With Quote
Old 10-10-2011, 03:27 PM   #3 (permalink)
Kevin Dougherty's Avatar
Thanks guys!
This is a known issue. Lubricate with Shin-Etsu, a white silicon grease available at Honda parts Dept., or equal, in the rubber channels after cleaning.
I do it every fall and that reminds me...
kevin
Old 10-10-2011, 03:34 PM   #4 (permalink)
thanks for your help guys!
Just for a heads up in case I do need one.... How much does a motor run
Old 10-10-2011, 03:43 PM   #5 (permalink)
$207 at Majestic Honda. PLEASE DO THE LUBRICATION FIRST. It will fix your problem.
Honda Automotive Parts
Probably a lot less at Flamboyant Auto parts.
items in Flamboyant Auto Parts store on eBay!
kevin
Old 10-10-2011, 09:47 PM   #6 (permalink)
Silicone lube spray or wd40 also works great in the window grooves.
Old 10-10-2011, 11:22 PM   #7 (permalink)
aisbell's Avatar
Another problem could be that the window channel at the rear of the door has slid up a bit causing it to wrinkle and bind the window. This happened to my 2000 Insight years ago. I had to attach the bottom of the window channel to the metal channel that it's in to prevent it from sliding up. There's an old thread in this forum that describes my fix.
Aloha,
Art Isbell
2000 Insight A/C #559
Old 10-11-2011, 07:50 AM   #8 (permalink)
this is a tad embaressing to ask but where do i apply the stuff (I'm not that car savy..my apologies)
Old 10-11-2011, 11:29 AM   #9 (permalink)
With a Q-Tip® and isopropal clean the rubber 'U' shaped channel that the window rides in and let dry.
Lube (more Q-Tips®)the vertical sections of the same channel, less is more. Any excess is to be cleaned off. Cycle window several times and repeat lube if necesssary.
kevin
Old 10-11-2011, 11:44 AM   #10 (permalink)
Lafter's Avatar
Thanks .. I'm having the same issue with the passenger side window.
Lafter is offline   Reply With Quote
