Bubbles that aren't water are usually caused by overfilling. Look at the bubbles and see if they're air or water. If they're water, flush and change the fluid, run it a day or two and change it again. If it's air, let it sit overnight and check it cold. If the cold level is above the low mark, you have too much. If it's near the low mark, you probably have the wrong fluid in there. If it's not reaching the dip stick at all or is way below the low mark, you're way low on fluid and sucking in air.
Chisight
