Car won't start IMA issues
For the past couple of months, the IMA light has been on, but overall hasn't effected the car that much. Once the weather turned a little cooler, the light went away until last week when going into a head wind, the SoC took a nose dive (which has been happening quite a bit lately) then the car started to charge again. When it neared the top, both the IMA and CEL turned on. After that, the IMA system has not been working. The car no longer goes into charge/assit modes nor does the stop/start work anymore. However, the car was still getting okay mileage, and still worked like a normal car. The only remnants of the IMA system is the car still starts using the IMA, however, it sometimes feels a little rough
Fast forward a week. I've put about 200 miles on it, and have actually been getting good mileage (55-60). Today I get in the car and try to start it up, and it sounds as if maybe the IMA was energized very momentary, but not enough to start the car. After a couple tries, it eventually fires up and I head on my way. Later in the day, I jump in the car to go to the store, try to fire it up and same thing. After a couple tries, it starts, and I'm on my way. Its dark out, so I have my headlights on, and I notice that at stop signs, my lights are a bit dim, but if I rev the engine, they perk up a bit.
In a normal car, I would say alternator. On this, I have no clue. Oh well, get out, run into the store, get back and try and start it. Nothing. Same symptoms, couple of halfhearted attempts by the IMA to kick on, but eventually, I am forced to call for help. First we try to just do a normal jump, an hook the jumpercables to the standard 12V. No go. Eventually we give up, and decide to try and just push start it. Turns out it works.
Now the question is, what do you think is causing this? Will a dead 12V cause this. Completely dead IMA battery? If I just take out the IMA fuse, would that cause the car to go purely ICE and then use the actual traditional starter?
*edit, its a 2000 MT
Thanks in advance for the help.
