corrosion between motor and engine housings caused by coolant leak? - Insight Central: Honda Insight Forum
Old 10-30-2011, 03:53 PM   #1 (permalink)
Default corrosion between motor and engine housings caused by coolant leak?
I had a pressure cooland leak test done, which didn't come up with any internal or external coolant leaks, but was told the test wasn't definitive. I smell coolant pretty strongly in the engine compartment, and I saw strong signs of corrosion between the motor and engine housings (location described by a friend, so I'm not sure how accurate his description is--but I definitely saw the corrosion).
Anybody know about this, how serious it may be, and any helpful solutions?
thanks!
00 5-speed, Citrus 168k
yogaguy is offline   Reply With Quote
