Originally Posted by pennyduke
When I bought my 2000 MT Citrus a week ago, the ground straps were fine. I took a look today and both have pulled out of the eyes and are broken. I had the same problem with Insight #1 2000 MT Silver.
What causes this to happen?
Will this cause a Check Engine Light?
Is it ok to drive with them broken?
My car was running at the time for a few days after one of mine was broken and showing no codes or irregularities.
The broken one was to the top portion of the engine that broke. The engine side broke on that one, the rest were intact.
I actually think I heard the noise of the top strap coming loose when I stalled the engine idling out with no throttle on a slight grade.
The fix for the cable cost me nothing, I reused, tested and reinstalled,
pic of repair effected is here, and the probable cause was
broken rear motor mount.seen in next image and later images.
.. the rear mount wearing out is pretty common as these vehicles get up in age i gather from all reports.
New rear mount at dealer cost me around $155 or something like that here in Canada. Cheaper elsewhere, say $80 via the net apparently. A new rear damper make the car nicer to drive and if you have juddering in reverse gear, that's a symptom.
