Originally Posted by Lafter
A little history
.... added to much oil
..... check engine light comes on .. .... economy.... about 10mpg.
.....2 P1164 Errors....
....smell rotten eggs ...very strong.
...every time I turn it off and get out.
... check engine lights go out.....fuel economy returns to normal ....still smell rotten eggs.
On 10-7-11 .... no check engine lights .. no smell.
What I don’t get is how the errors cleared themselves.
Can anyone explain what happened?
Interesting, ....glad no hard to replace seals were blown
Possible scenario in engine:
...overfilled oil pushed past worn guides, ..oil partially burned in combustion, ...fouled LAF sensor & likely cats downstream, ...stoichiometry went to the fat side, ...cats then clogged more.. threw codes, ... car needs run rich to burn residue in cats...mileage bad
The hydrogen sulfide gas H2S a.k.a rotten egg smell produced in absence of O2 takes scant ppm of the poisonous gas to smell. Your sense of smell will attenuate with acute exposure and in some cases only others where you roll up will notice the odor.
...after some vehicle use running up to hot operating temperature, the heat burned the contamination ..., functional again, yay......
after 3x good as stated ECU does code self reset as programmed ,...
///remaining residue continues burning off...
... stink persists with diminishing output to point of extinction
_____________
Hope the ERG plate will be ok.
Any jerkiness following up?
Did you actually remove the extra oil as planned? ... a Fumoto drain valve is perfect for that scenario.
Larger Mobile 1 filter?? What size? p/n
TIA
