EPS not working - Insight Central: Honda Insight Forum
Old 11-11-2011, 03:35 PM   #1 (permalink)
pennyduke's Avatar
Default EPS not working
Today I started to try and fix my Power Steering in my 2000MT Citrus I just acquired 2 weeks ago. After reading a bunch of posts, I replaced the short corroded ground wire from the EPS to the fire wall thinking this would be the cure. Nope. Then I switched the 40amp fuse with one from the power windows and still no power steering. Fuses are good. Is there another fuse somewhere or am I looking at a new expensive part. What should I do next. Thanks all, Mike
Mike
pennyduke is offline   Reply With Quote
Old 11-11-2011, 03:57 PM   #2 (permalink)
Is the EPS light on?
Old 11-11-2011, 04:13 PM   #3 (permalink)
pennyduke's Avatar
Yes Sir, It's been on since I bought the car. Even after disconnecting the battery and pulling the fuse to recharge the IMA battery.
Mike
Old 11-11-2011, 04:19 PM   #4 (permalink)
What is the code?
Might be a good place to start. Just sayin'...
Old 11-11-2011, 04:30 PM   #5 (permalink)
pennyduke's Avatar
The only codes I get are P1162 and P0420. And the EPS light of course.
Mike
Old 11-11-2011, 04:31 PM   #6 (permalink)
Yeah, you'll have to short the SCS pin on the OBDII connector to get the blink code.
Reading Vehicle Error blink codes
Old 11-11-2011, 05:12 PM   #7 (permalink)
pennyduke's Avatar
Did the short test and got 16 and 23 counting the EPS light and 61 and 54 counting the IMA light.
Mike
Old 11-11-2011, 05:16 PM   #8 (permalink)
pennyduke's Avatar
oops, It was the ABS light that flashed the 61 and 54 code. Sorry
Mike
Old 11-11-2011, 05:27 PM   #9 (permalink)
16 is a problem with average voltage of torque sensor VT3 and VT6
23 is a problem with the engine speed signal
Old 11-11-2011, 05:49 PM   #10 (permalink)
pennyduke's Avatar
Is there a quick fix?
Mike
