battery fans not coming on - Insight Central: Honda Insight Forum
Old 11-14-2011, 05:56 PM   #1 (permalink)
sam
Question battery fans not coming on
Hi. I'm a noob. But i'm learning quickly thanks to you folks!!! Anyway, my insight was running great put then the battery woould nolonger charge then the ima stoppped working and when I pulled the battery covers off I saw fans. Well these never came on while I was driving. UNLESS they're so quiet no could possible hear them. I energized the fans and they work checked the relays and their fine so my question is:
1) WHAT IS KEEPING THE FANS FROM TURNING ON?
2)what exactly does "SOC" stand for?
P.S. my codes are p1447 and p1449
sam is offline   Reply With Quote
Old 11-14-2011, 06:06 PM   #2 (permalink)
The fans are very quiet and you cant hear the most of the time.the codes you have are a bad ima module.
REDFLYDOG is offline   Reply With Quote
Old 11-14-2011, 06:25 PM   #3 (permalink)
SoC = State of Charge
As stated, the fans are quiet, you can't hear them with the IPU cover on.
P1447/9 = bad battery.
Old 11-14-2011, 10:57 PM   #4 (permalink)
sam
Default can the battery be reconditioned or is it done?
Old 11-14-2011, 11:04 PM   #5 (permalink)
It can be reconditioned.
