Blink codes:22, 61, 69 - Insight Central: Honda Insight Forum
Old 11-18-2011, 05:58 PM   #1 (permalink)
sam
Default Blink codes:22, 61, 69
Hi,
I had a dead battery and have been reconditioning it with a 2 amp trickle charger. I got it almost fully charge and decide to check the codes. I got a MIL code(check maintenance light) code of 69. And EPS code of 22 (is this an all clear code?). Also, an ABS code of 61. These codes are not in the service manual or in any of the links I have found on this site. Does anyone know what these are?
P.S. Thank you all for this great site and your time and responses. You folks are the best!!!
Sam
sam is offline   Reply With Quote
Old 11-18-2011, 08:33 PM   #2 (permalink)
CEL 69 = IMA System problem. This comes on when the IMA light is set.
EPS 22 = either "Excessive change of the Vehicle Speed Sensor" or "A problem with the average vehicle speed and engine speed"
ABS 61 = "FSR +B Voltage". The diagnostic says to check the charging system if this is indicated. May be a ground strap issue?
