I've never read about jerking or bucking caused by the IMA motor. If it were to blame, I would expect a warning light to illuminate and a diagnostic trouble code to be set. But not every problem can be diagnosed automatically, so maybe your problem is one of these rare ones.
My guess would be a CVT-related problem. Maybe under higher power conditions, the start clutch or drive belts are slipping. Do you notice the engine RPM varying when this jerking and bucking occurs?
Aloha,
Art Isbell
2000 Insight A/C #559
