Looking at an Insight with IMA error
All, been away for a year, found a 2001 MT UK Insight currently on then market.
Its not in great shape but needs some TLC.
Just been to see it and for a test drive...
Drove OK 104,000 miles.
Service book stamped by the same Honda dealer all the way till 96000 miles when it went to an independent.
Wheels are very rough and will need a refurb. Drivers front wheel has seen some action with a big dent, tyre was flat needed air. Wheel may need to be replaced...
Body ok no real dents, a few scratches here and there as expected for miles...
Engine started and sounded fine, IMA light on solid and battery light on solid.
Tickover a little fast (if i recall) at 1250ish but think I read that is normal when IMA disabled?
Spare BCM and MCM? On passenger floor (vendor told IMA error was modules) has changed them to no effect, originals in car.
Interior very good for miles, could do with a clean and new mats all superficial. Underside looked fine could not tell if aero parts where all in place.
65 life mpg (imperial)
Vendor says that he took it to a Honda dealer and they told him the fault code was 66-1. I was expecting a Pxxxx code.
Read the sticky section on blink codes and could only find P1568 (66)*2 & P1570 (66)*3. Both of these have the same description, and match the text the vendor was given for the fault, "Battery Module Individual Input Problem".
Can any one elaborate on what that actually
Regards
Richard
PS: Not expecting a working pack, and if I buy know that I will need to buy a new one, but just wondering if grid charging or any other action will get the current pack servicable/with faults while i wait/save...
Insight owner since 7th Feb 2009
2002 Red 5 Speed MT 165,000 Miles (OBDIIC&C)
Projects Planned: IMAC&C, Rad Block, Block Heater, Grid Charger
2007 Silver A8 3.0 TDI now passing 136,000
Previous Owner of a: 2005 Silver Manual Insight with 25,000 miles. lmpg 81.9
Previous Owner of a: 2001 Black A2 1.4 TDI 87,000 miles,
All my cars are Aluminum (I think its magnetism)
