Rear suspension bushes
Today my 2002 Insight had its 90,000mile service, and I was told that one of the rear arm bushes on the rear beam axle was splitting and would need to be replaced before long, and that the one on the other side was not too good either.
Apparently, the bushes are not available as individual parts, and the official Honda advice is that it will be necessary to have the entire rear beam axle replaced at a cost of several hundred pounds. The rear beam axle itself is not rusty or damaged in any way.
I would have thought that it should be possible to obtain replacement bushes of a suitable size and type, possibly polyurethane ones, from some after-market supplier and fit them in place of the worn ones.
If anyone else has experience of this problem, and has found a solution other than the one recommended by Honda, I would be grateful for the information.
