Bad Fan Motor? - Insight Central: Honda Insight Forum
Old 01-26-2012, 04:54 PM   #1 (permalink)
Default Bad Fan Motor?
I think I may have a bad Motor Power Inverter fan motor. I have a moderately loud sound from the IMA box in the rear. Sounds like a loud cat puring, with and slight drumming note, just like the cat, and a bit "tinny." I have manual control over the Battery Module Fan and can vary its speed so I have eliminated that source. Anyone had this problem? Does my diagnosis sound anywhere like correct. I can't think of anything else back there which has mechanical motion or rotates.
BTW, what is the warranty period/mileage limit on the 2006? I'm second owner and the warranty booklet, if there was one, seems to be missing.
Old 01-26-2012, 05:32 PM   #2 (permalink)
I have noticed the same noise. I think the blower is just noisy, though it's fairly hard to hear if the IPU cover is on...
Old 01-26-2012, 06:33 PM   #3 (permalink)
The crz sounds like a leaf blower. Since I took your inflammatory suggestion my fan is noisy as it had all these baffles softening the sound.
Old 01-26-2012, 06:42 PM   #4 (permalink)
Mine is pretty loud. I don't even have good hearing and I hear it with no trouble. It just started. Had not noticed it before. You think might be the MPI fan? I can't think of anything other than the pack fan, which has been eliminated, that rotates.
Guess I'll have to take the cover off.
