Heated rear screen element trouble! - Insight Central: Honda Insight Forum
Old 02-16-2012, 06:18 PM   #1 (permalink)
o..
o..'s Avatar
Default Heated rear screen element trouble!
Hey all,
I only have about two bars left that actually work on my screen - Does anyone know a way of repairing this? Don't really want to have to buy a new one
Thanks in advance,
o
Genuine UK Honda Insight - 298,000 miles and counting..
o.. is offline   Reply With Quote
Old 02-16-2012, 07:19 PM   #2 (permalink)
Mine did the same thing. The end of "lines" burn because it is always on under 0 deg celcius. I bought some VersaChem 90130 kit on ebay, and repaint end of lines.
You have to apply paint for about 3 inches on the line, and go over the conductive border on the side of windows.
VRS-90130 - VersaChem 90130 Rear Window Defogger Repair Kit
I have also tried the permatex kit. It does not last. Versachem is a 2 parts epoxy mixed with silver powder.
Old 02-16-2012, 09:00 PM   #3 (permalink)
only a few of my lines work. The ones towards the bottom and that little window I believe.
Were you able to see damage to the lines? How did you know what to repaint?
insightbuyer is offline   Reply With Quote
Old 02-16-2012, 09:40 PM   #4 (permalink)
yes you if you look closely, you will see that the color is different on the end
Old 09-27-2012, 04:50 PM   #5 (permalink)
Default Rear defogger
Was this kit very difficult to install? I did a little t/s today and the values were not what expected. I can definitely see discoloration on both sides of the glass where the metal conductor attaches and spreading out towards top and bottom. Does that issue also happen on the small rear window? Any tips appreciated. Thanks.
2001 CVT #3313, 52k, LMPG 47.6 and rising!
MODs:
-Rostra C/C -Fumoto oil drain valve & hose -Upgraded trip switches -Kenwood Excelon KDC-X696, Infinity Reference 6032's
-Prototypist's Actuator upgrade
-Heated mirror upgrade -Frost Fighter Clear View defrost kit
Best Segment: 73.3mpg @ 75 miles
GasSipr37 is offline   Reply With Quote
Old 10-01-2012, 10:08 PM   #6 (permalink)
NorthwestIL's Avatar
Y’all my rear defrost is out too except for those bottom 2 lines. Anyone else have the best repair ideas on fixing the defrost lines?
329,000 miles 2001 CVT Insight Virgin
soon to have MiMA/ grid charger/OB Guage
(too dumb & scared to install the GREAT stuff??
339,000miles hot coolant -cracked head, replace radiator cap1900 dollars
use OEM tires,.0w20 Mobile One,civic oil filter,and 87 octane
(badly dented front and rear bumpers still a problem 2012) fixed aug 2012 Rockford, IL
NorthwestIL is offline   Reply With Quote
Old 10-01-2012, 11:01 PM   #7 (permalink)
Try Frost Fighter Defroster Repair and Replacement Kits
Use: 320,000 mi. @ 57.8 LMPG
07 FIT "S"
(3K made, The prototype one?)
Old 10-02-2012, 07:12 PM   #8 (permalink)
I did many tests. The only one that last is the epoxy base versachem repair kit. The regular (non epoxy) peel after a couple of weeks.
http://www.cafr.ebay.ca/itm/VersaChe...item5d3282e77d
Old 10-19-2012, 10:37 AM   #9 (permalink)
bryankwalton's Avatar
Based upon this thread, I've ordered and received this Versachem repair kit. Talonmike, is it only important to do the parts that look faded? I can't seem to see a different color on the lines. But I can see a difference on the border along the outsides. Looking at the kit last night, the outside packaging states that it is good for repairing up to 10" of lines. If I need to redo 3" on each line, this could take a lot of these kits.
-Bryan
2000 Honda Insight -- Lifetime Fuel Economy of 72.3 MPG
Old 10-19-2012, 11:01 AM   #10 (permalink)
I bought 4 kits. I did like 6 inches on each lines on both sides. In my case, all the end of lines were faded. Clean well with alcohol before.
