Sourcing Spark Plugs - Insight Central: Honda Insight Forum
Old 03-12-2012, 06:34 PM   #1 (permalink)
Default Sourcing Spark Plugs
What is a good source for the indexed plugs for the Gen 1? I tried Majestic and a couple of other internet sites but only sound the A plugs on one site. I need the C plug.
Old 03-12-2012, 07:40 PM   #2 (permalink)
?? Majestic has them all...
Honda Automotive Parts
12290-PHM-A01 = A
12291-PHM-A01 = B
12292-PHM-A01 = C
12293-PHM-A01 = D
503-730-8786
info@bumblebeebatteries.com
Old 03-12-2012, 09:54 PM   #3 (permalink)
Thanks Eli,
I'm a dummy. I didn't realize that spark plugs could only be found under the heading "ignition coil." But not to worry, I always have a friend to help on IC.
Old 03-15-2012, 02:34 PM   #4 (permalink)
Cross shop G1parts.com.
Regards,
Jerry
2004 MT Silver Bullet
West Palm Beach, Fl.
Old 03-15-2012, 04:07 PM   #5 (permalink)
diamondlarry's Avatar
Originally Posted by jime View Post
Thanks Eli,
I wouldn't say you are a dummy. Majestic's website is goofy in that you have to know what group something is in and you can't search for a specific part or part number. I was looking for the underbody panels recently and couldn't find them anywhere because they were listed in, get this...the "front fender" section. Is it just me or does that not seem like where underbody/aero panels should be? At any rate, now I'll know where to look for my "B" plugs in another 90K miles or so.
Silver '00 MT
90.2 LMPG
Calpod switch
Warm air mod
Grill block
EPS fuse removed
grid charger
OBDII C&C gauge
Old 12-28-2012, 11:04 PM   #6 (permalink)
olrowdy01's Avatar
And the strakes are shown under "Bumpers".
I'm still trying to figure out where #5, 6 & 7 mount on the fender drawings. Of course having my face 2" from everything doesn't help in identifying parts while I'm under the car.
Sorry for the hijack but not counting #9 in the fender drawing, how many removable aero panels are there? I only can find 2 listed in the all the drawings. Is there a panel located between #12 & #17? If so I sure can't find it in the drawings. As you can tell my car is missing some panels under the front end.
TNX
2005 Insight, MT, 88K, Silver
1988 Honda CRX HF, 44/51 mpg
1963 Lotus 7 replica, 12 mpg
http://dmr-architect.com/~locouki/
olrowdy01 is offline   Reply With Quote
Old 12-29-2012, 04:14 PM   #7 (permalink)
nothing between 12-17. not sure about that other plate. ive never noticed it (or had to remove from snow damage lol)
ac
295,000miles
Old 12-30-2012, 12:41 PM   #8 (permalink)
Default Honda plugs worth it?
Has anyone found a real world improvement with the factory spark plugs over the non-indexed aftermarket ones?
MLN63 is offline   Reply With Quote
Old 12-30-2012, 03:07 PM   #9 (permalink)
No actual "scientific" proof. Just "seat of the pants" conclusion. For a complete burning process and mainly for emissions, stay with the OEMs.
Use: 321,000 mi. @ 57.8 LMPG
07 FIT "S"
(3K made, The prototype one?)
Old 12-30-2012, 03:11 PM   #10 (permalink)
Is there a age requirement on these plugs also? As my car in a 2003 (10yrs old) but only has 60k miles? Maybe it wouldnt be a bad idea for me to change them this spring with the next oil change?
2003 Honda Insight MT 46K MIMA 164P
dls1981dustin is offline   Reply With Quote
