Ima battery switch-difficult to switch - Insight Central: Honda Insight Forum
Wheel & Tire Center
Old 05-03-2012, 09:23 PM   #1 (permalink)
Post Ima battery switch-difficult to switch
Just thinking what a great resource this is....THANK YOU for all the concerted effort to keep this website and community going. i am new to the Insight. i wanted to swith off the IMA pack switch, but it seems resistant to being moved. i don't want to force it and possibly break it i the process. Has anyone noticed this situtuation?? Thanks very much for any info. i love my Insight, but i am worried that i may not be driving it often enough to kee up the IMA battery health. Best regards, -john
CITRUS 95060 is offline   Reply With Quote Quick reply to this message
Old 05-03-2012, 09:31 PM   #2 (permalink)
Rainsux's Avatar
You have to remove the little red cap. Just pull it straight up. Then flip the switch and replace the red cap in the opposite direction. This prevents you from inadvertently turning the switch off or on.
Sam (Another Citrus)
2000 Citrus
Custom Turbocharger System
MIMA #150
BumbleBee Battery
OBDIIC&C Gauge
NM license plate KERS
Alpine Stereo
GAZ rear shocks
Rainsux is online now   Reply With Quote Quick reply to this message
Old 05-04-2012, 12:06 AM   #3 (permalink)
Default Oh!! so that's how the switch works!!
i wish i had the mechanical & engineering abilities common with the Insight veterans, but i love the car and am determined to learn what is needed to keep her going strong. Sam, thanks so much for your help AND for spreading the Citrus Insight cheer in the Southwest. -john
Old 05-04-2012, 02:48 AM   #4 (permalink)
eq1
eq1's Avatar
FYI, I recently realized that you can charge your battery by revving the engine past 3000 rpms, and hold it there. If it works like my car, then you'll get a good 10+ amp charge, which charges fairly quickly... So if you don't have time to drive it, just running it for a bit, letting it rev, would be an option. I don't think many people realize that they can do this; unless you read about it somewhere or have an external gauge, it'd be pretty hard to tell you're getting this kind of charge. I don't think the green charge bars light consistently when you're getting this charge, though I have seen them light up...
2000MT, CAN, ~168K miles
Old 05-04-2012, 10:50 AM   #5 (permalink)
Hey Citrus,
Please add your location to your signiture block, where at in the Southwest?
Old 05-04-2012, 05:45 PM   #6 (permalink)
Smile Stored Vehicle -run >3000rpm to charge IMA
Oh, THANKS! That is great to know. i don't want to be guilty of Insight abuse(or have premature IMA battery failure). i will be sure to give it a good run at over 3000 rpm if it is not being driven for a while. Any idea how long to run it? -and how frequently? i seriously am so over my head with the tech aspects of this car that i could not make it with out the help of the Insight Central community. Best to you all. -john
Old 05-04-2012, 10:29 PM   #7 (permalink)
eq1
eq1's Avatar
Hmm, I don't think the dash SoC gauge shows a loss in SoC after inactivity over relatively long periods, that is, I don't think it goes from say 19 bars down to 18. Maybe someone else can confirm or refute this. If it DID you could rev over 3000 until you got it back to 19 bars...
We can do some rough calculations. I saw my individual sticks losing about 1% per 24 hour period. Not the most precise measurements/calculations but a start. If at the start I had a fully charged battery at 6500 mAh, after a week I'd be at 6058 mAh, a loss of 442. Revving above 3000 rpms, putting out, say, a 10 amp charge, it'd take about... I think it'd be about 2 1/2 minutes to get that 442 mAh back. A charge at 442mA, or 0.442 amps, would take 1 hour. But we've got a 10,000 mA charge. I think you can just divide 10000 by 442, and then divide 60 minutes by the result (so 60 minutes / 22.6 = 2 minutes 39 seconds)... Sounds about right to me.
You could get an OBDIIC&C gauge, which shows the SoC % and amps-in and amps-out: you can see that the "amps in" number turns to zero when the charging reaches the max possible under this rev regime...
Roughly, I'd be starting my car at least once every other week and revving it above 3000 rpms for 5 minutes if I wasn't driving my car regularly...
Old 05-05-2012, 06:37 AM   #8 (permalink)
aisbell's Avatar
You could disconnect the negative cable of the 12 v. battery for more than 15 seconds, reconnect the cable, start the engine, and run it at 3,500 RPM until the charge level gauge reads 19 or 20 bars. By disconnecting the 12 v. battery, the charge level information is lost, so the charge level gauge would read empty even though the battery pack isn't empty. The gauge would recalibrate to full when the battery pack's voltage or, if the battery pack is significantly unbalanced, that of one of its pairs of 6-cell sticks reaches an upper limit. At that point, the battery pack is as full as the IMA system can make it, so shut off the engine.
If you don't disconnect the 12 v. battery, the charge level gauge would read too high because it doesn't measure the charge lost due to the self-discharge that naturally occurs when the battery pack isn't being used (i.e., when the car is parked). So the charge level gauge would read full before the battery pack is actually full.
Aloha,
Art Isbell
Uppsala, Sweden: FOR SALE!: 2000 Insight A/C #559 with Honda security system, Genesis One MIMA+FAS and grid charger, OBDIIC&C, Rostra, Fumoto, DEFA engine block heater, Philips LED DRL's
Honolulu: 2014 BMW i3 BEV
aisbell is offline   Reply With Quote Quick reply to this message
Old 05-05-2012, 12:50 PM   #9 (permalink)
Default Top off IMA battery charge of stored vehicle
Art, THANKS VERY MUCH for the great information. i am trying to drive the car on a more regular basis now, but it is great to know how to maintain the pack SOC when it is parked. -MUCH to learn. best regrds, -john behrens
Random Question
