This is interesting... random speeds on the dash - Insight Central: Honda Insight Forum
Old 06-07-2012, 06:23 PM   #1 (permalink)
Default This is interesting... random speeds on the dash
Well, the saga continues. My wife has the car, but she just called and stated that the readouts on the dash are going bonkers. Specifically, she is parked and the speedometer is going from 8 to 80 and bouncing everywhere inbetween. The mileage display is also going weird. Anyone heard of this? No IMA lights, no check engine either.
Roy Simpson
2000 Honda Insight
180,000 miles
Grid charger
1st IMA battery replaced at 78,000 miles
Average Lifetime Mileage: 55.6 mpg
Best: 78.2 mpg (trip from Placerville to San Diego)
mathemaddicts is offline   Reply With Quote
Old 06-07-2012, 09:49 PM   #2 (permalink)
You are the first, check ALL the grounds that go to the 12v battery. Hook a voltmeter to the battery and see if you are getting the correct voltage. 13.8-14.2 for a start.
Use: 321,000 mi. @ 57.8 LMPG
07 FIT "S"
(3K made, The prototype one?)
Old 06-07-2012, 10:07 PM   #3 (permalink)
highwater's Avatar
something to check also
unplug
clean
wiggle
wheel speed sensors
Randall
MIMA #005
Thank You to all the "Mid-Atlantic" Insighters
highwater is offline   Reply With Quote
Old 06-07-2012, 10:38 PM   #4 (permalink)
Wow. Again, everyone on this forum is awesome! It is a broken ground strap. I recently had the motor mounts replaced and all that shaking must have damaged the ground strap.
Roy Simpson
2000 Honda Insight
180,000 miles
Grid charger
Old 06-16-2012, 06:44 PM   #5 (permalink)
Well... here is the proof of the funness.
https://skydrive.live.com/redir?resi...K6HNKujcdiNvc0
Roy Simpson
2000 Honda Insight
180,000 miles
Grid charger
Old 06-16-2012, 07:27 PM   #6 (permalink)
so did the ground straps fix the problem or is it still happening? Maybe check the speed sensor on the transmission, so if the connector isnt loose or something.
Hello
Old 06-16-2012, 07:58 PM   #7 (permalink)
One of the ground straps was holding on with half of its threads, so I had that replaced. This video was shot after the replacement (but is the same behavior as before sans the Check Engine light).
Roy Simpson
2000 Honda Insight
180,000 miles
Grid charger
Old 06-18-2012, 02:37 AM   #8 (permalink)
Jeff found out that it was a lose connection on the speed sensor. To think that the Honda dealership started quoting me prices for a new IMA battery.
Roy Simpson
2000 Honda Insight
180,000 miles
Grid charger
Old 06-27-2012, 10:59 PM   #9 (permalink)
RedJellyBean's Avatar
I was THIS || close!! to blaming dissociative drugs like phencyclidine as the cause of the problem, LOL.
2002 Honda Insight 5MT
Old 06-28-2012, 04:30 PM   #10 (permalink)
Whoaaaa mannnnnnnnnnnnnn.......
503-730-8786
info@bumblebeebatteries.com
