CEL & ABS on, no assist, no IMA charge, no BAT - Page 3 - Insight Central: Honda Insight Forum
Old 10-19-2012, 05:37 PM   #21 (permalink)
Hm. Really was hoping it was fuse #24. Have you verified it with a multimeter, or just giving it a look?
503-730-8786
info@bumblebeebatteries.com
Old 10-19-2012, 07:00 PM   #22 (permalink)
Used a meter. It's good.
I just turn the IMA switch off and unplugged the BCM for my trip back to work. I'll be looking at it again when I have time, or maybe taking it to Eric when I get back to WI.
Thanks again to everyone! I will be checking here tomorrow and periodically.
dbkinney is offline   Reply With Quote
Old 12-17-2012, 09:03 PM   #23 (permalink)
ericbecky's Avatar
David did bring this car in to EV Powers and we found the root of the problem and the negative results that occurred because of it.
Looks like when the engine was swapped the harness was attached to it.
So when the harness was reinstalled it was improperly routed.
Because of this the wire loom was in harms way. It actually sat on the steering rack, and each time the whell was turned, it made a sawing motion on the loom.
Eventually the loom wore through, and then the insulation started wearing off a few wires.
Ultimately one wire on DTC sensor 1 broke causing a CEL.
Also, here are some sharp edges on the firewall where the harness must pass through. They are usually covered by a grommet, but the grommet must be removed when passing the head of the wiring harness through. When the wire harness was inserted through the firewall it incurred quite a bit of damage, scraping off wire insulation and also breaking off at least one wire to the ECU.
So it took quite a while to track all down all these electrical problems, but ultimately we fixed the broken wires, covered the worn insulation, and rewrapped portions of the harness loom.
Put it all back together and now no more CEL codes.
We also fixed the dangerously loose crimp connectors on the aftermarket grid charger wires.
There are still a few other things, like the ABS light and huge rattle in the rear end.
But at least now the battery is charging and the car does not go nuts over 3,500 rpm.
EV Powers: A Green-vehicle workshop in Madison, WI
Eric@EVPowers.com
608-729-4082
http://www.EVPowers.com
ericbecky is offline   Reply With Quote
Old 12-17-2012, 10:46 PM   #24 (permalink)
Great work Eric finding the root cause of the issue, those kind of issues can drive you crazy trying to find it. Like I always like to ask.... "what was the last thing you did to it"!
Old 12-18-2012, 03:51 PM   #25 (permalink)
ericbecky's Avatar
Figured out the rattle in the rear end... dangerous.
An alternate set of steel rims is on the car (Mazda).
The centering hole is too small, so the tires actually tightens against the hub cover rather than flat to the brake drum. So there is a metal clang and rattle since there isn't pressue against the drum.
Trying to find a used set of rims in the area, but not having luck. 97-2000 civic rims, anyone?
Eric@EVPowers.com
608-729-4082
Old 12-18-2012, 04:11 PM   #26 (permalink)
Eric;
Possible "lathe" time?
Temp. solution.
Use: 320,000 mi. @ 57.8 LMPG
07 FIT "S"
(3K made, The prototype one?)
