Highbeams won't work - Insight Central: Honda Insight Forum
Old 10-26-2012, 06:21 PM   #1 (permalink)
Default Highbeams won't work
Whenever I go to turn my highbeams on or flash someone, my bulbs completly shut off. Has anyone ever had this problem before? Is this a common problem?
The bulbs are only a year old.
cah155 is offline   Reply With Quote
Old 10-26-2012, 06:56 PM   #2 (permalink)
There was a recall on the Headlight switch some years ago.
Maybe someone will post the link.
The dealer should be able to run the Vin # and see if the recall was ever done.
Use: 321,000 mi. @ 57.8 LMPG
07 FIT "S"
(3K made, The prototype one?)
Old 10-26-2012, 07:44 PM   #3 (permalink)
AbCaRed00's Avatar
gilbertguyand the OP had it figured a ways back
Step by step guide for replacing headlamp switch?
and referenced:
Honda Insight Repair and Upgrade Blog by Mike
from the pdf that downloads by clicking
Honda Service Bulletin 04-015
Safety Recall: Combination Light Switch
(Supersedes 04-015, dated March 26, 2004)
CORRECTIVE ACTION
Replace the combination light switch, the RED/WHT
wire in the headlight wire harness, and if needed, the
16P headlight wire harness connector.
PARTS INFORMATION
Combination Light Switch Repair Kit:
(Includes switch, wire harness connector, 250 mm
wire with an attached terminal, and wire splice
connector)
Civic: P/N 35012-S5A-307, H/C 7743875
Insight: P/N 35012-S3Y-306, H/C 7743883
__________
'hope that helps
Current Gasoline Economy@ 221,000km : 4.3 L/100km LMPG
Old 10-27-2012, 05:28 PM   #4 (permalink)
I will call Honda Monday and see if they can help out. I looked it up online today and saw it has been replaced under warranty once already
Thanks for all the help guys!
Old 11-07-2012, 06:46 PM   #5 (permalink)
It was replaced under warrenty again Thanks for all your help! Made this process much faster/easier!
