Bad ground or? - Page 4 - Insight Central: Honda Insight Forum
Old 12-01-2012, 07:39 PM   #31 (permalink)
Just went on for a night time test.12v battery fully charged, ran about 25 mi with headlights, heater motor, wipers on some and radio going. When going down the road, the Bat/Brake light was off or faint depending on the rpms. Finally the dash lights went out, cut off the heater, they came back on but no power steering.
Any ideas?
fishtrap is offline   Reply With Quote
Old 04-01-2013, 08:23 AM   #32 (permalink)
fishtrap, did you ever figure out this issue? I have a similar problem with my 12v that has been going on for quite some time, and I cannot nail down the source of the problem. Originally, when I had this issue, I found the connection from the IMA to the DC/DC converter to be loose. Tightened it up and drove 6 months without issue. Now, it's reappeared and that fix isn't working.
Essentially, I'm having similar problems as you with the brake and battery lights slowly flickering on (the rest of my dash works, though, unlike yours). I've resnugged all the grounds (they are 6 months old, replaced those last time, but I should probably clean the contact surfaces), checked the fuses, disconnected the IMA system properly even though it was working, but the issue persists, and I cannot pin down its source yet.
Just wondering if you had any such luck? I'm thinking it has to be a short somewhere or the DC/DC converter is dying because the battery and brake lights aren't consistently on. Instead, they slowly flicker on when the 12v is near death. For instance, during my commute to work this morning, they started to flicker on, then became solid, so I turned off my headlights, they went off, and I was able to get to work with the lights only faintly flickering on as I turned hard into my parking spot at low speed (surely EPS causing the flicker on a low battery).
Thanks for any help and hope you have figured it out! I'm sick of carrying two 12v batteries in the car
helpstranded is offline   Reply With Quote
Old 04-01-2013, 08:25 AM   #33 (permalink)
Actually, just saw the other thread about Fuse #4... going to check that at lunch. Hopefully that is the issue!
Apologies for the possible unnecessary thread revival.
Old 04-01-2013, 09:25 AM   #34 (permalink)
At least we are in the same state altough 8 hrs away! lol I used a electrical contact cleaner that we use here for boats. And then replaced the fuse with a new one. Like I said before, the old fuse looked and tested ok but wasnt. The second that I plugged the new one in it was fixed. About 30 days of trying to fix it and plugging my 12v battery to a charger after just 7 miles. text me if you like 252-305-1920, not always near a computer.
