SRS warning light - Insight Central: Honda Insight Forum
Wheel & Tire Center
Old 11-20-2012, 04:30 PM   #1 (permalink)
Bugone's Avatar
Default SRS warning light
Hi,
I've had an SRS warning light since I've had the car.
I should probably take it to Honda, but it'd piss me off if I have to spend a fortune replacing loads of components, if it was just a loose connection.
Does anyone know where I should be checking for loose connections or is there is a way to narrow down which component is faulty? (I have a ODBC C&C gauge now).
Bugone is offline   Reply With Quote Quick reply to this message
Old 11-20-2012, 06:37 PM   #2 (permalink)
It should generate a code on an odb2 scanner. On the i2 for example disconnecting the passenger side indicator will trigger the warning. I wonder if something is just unplugged as a poor mans way to disable the system?
Old 11-21-2012, 12:36 PM   #3 (permalink)
I've had the same issue and haven't had time to dig through the site looking for answers. My car needs to get inspected and i don't feel like paying a dealership to fix something i can do myself. I can't read any codes with my scangauge so i'm not quite sure where to start also.
Tim
2000 Red MT "Wendy" 152k miles, Rough shape, but she's back on the road!
Sold section
2000 Silver MT #168 130k miles Grid charger harness, CARD switch, rad block, MIMA #174, BetterBattery 83.5Lmpg
Bests trips: One way 58.2 miles-110.4 mpg
round trip 116.8 miles-99.5mpg Tank: 94.4mpg
2001 Blue CVT - 203k miles 69.3Lmpg Best 56.6m-92.3 mpg Tank: 75.13mpg
timny1984 is offline   Reply With Quote Quick reply to this message
Old 11-21-2012, 01:43 PM   #4 (permalink)
Lean Burn = Happiness
jeff652's Avatar
Just reset it and see if it comes back. All you need is a paper clip (instructions are in the free Helms manual download on this site).
Extending the life of your hybrid
Best Tank: 90.2MPG over 918.7 miles 010MCM/030BCM, No MIMA. Details:
2006 Dark Blue Insight. Bought/Selling/Sold/Dismantled nine silvers, three blues, and a Citrus
jeff652 is offline   Reply With Quote Quick reply to this message
Old 11-21-2012, 02:25 PM   #5 (permalink)
Bugone's Avatar
Hi Jeff,
Is that the Insight Resource Manual? (Link to here Download 2000-2006 Insight Service Manual PDF and Others)
Only that link is dead.
Any chance you could describe the procedure?
Old 11-21-2012, 02:36 PM   #6 (permalink)
jeff652's Avatar
Here you go: How do you reset 'blink' codes / subcodes?
Old 11-21-2012, 03:26 PM   #7 (permalink)
Bugone's Avatar
I think I've managed to extract the procedure from the manual.
SRS Reset Procedure.
Old 11-22-2012, 05:53 PM   #8 (permalink)
Bugone's Avatar
Tried the procedure tonight (a jumper wire worked fine, desire the honda instruction saying otherwise). I now have no warning lights.
Thanks guys
Old 11-22-2012, 06:41 PM   #9 (permalink)
freezin4's Avatar
Paper clips work, but it's hard to keep them in there while trying to count the flashes on the dash.
I used the red and black wires from a volt meter. I poked the pin ends into the plug and used the aligator clips to touch while watching the dash.
99% of questions answered here:
Insight T-Shirts 4Sale: PM Me.
CDN Aquamarine Blue 01 DD
Silver 01 5spd #0160 Sold to fellow Insight owner
Citrus #1159 Sold to Insight Fan
Red '00 A/C project SOLD to fellow Insighter friend
Citrus #2083
Sold to a fellow Insight owner.
Red '01 A/C parts car.
freezin4 is offline   Reply With Quote Quick reply to this message
Random Question
