Removing dash and cluster - Insight Central: Honda Insight Forum
Old 11-25-2012, 02:44 PM   #1 (permalink)
Default Removing dash and cluster
How does the dash cover come off without breaking it? Took the 2 screws out. And which plug is for the speedometer?
Thanks
fishtrap is offline   Reply With Quote
Old 11-25-2012, 03:01 PM   #2 (permalink)
did you remove the screw hidden behind the a/c vent center cap? The rest is clips. After you remove this, the cluster has more screws around it and two connectors on back (MT), three if its CVT
Old 11-25-2012, 03:32 PM   #3 (permalink)
Thanks, didn't know about those 2. Try to unplug them first and look at connections..
