Output of DC/DC converter - Insight Central: Honda Insight Forum
Old 11-27-2012, 04:11 PM   #1 (permalink)
Default Output of DC/DC converter
What should it be at idle? Mine is reading 11.6v
fishtrap is offline   Reply With Quote
Old 11-27-2012, 04:24 PM   #2 (permalink)
It should read 14v if the IMA system is supplying it with power. If it is uner load and the 12v battery needs charging and the IMA battery isn't supplying power, the voltage would be lower but not that low. 11.6v should be triggering the 12v charging fault indicator.
My Scangauge pretty much always reads between 13-14.2v
Old 11-27-2012, 04:59 PM   #3 (permalink)
IMA battery is dead and BCM disconnected. Something happened all of a sudden and been looking for the problem. Either at idle or driving DC/DC is at 11.6v. Is it shot or some component?
Have checked all the wiring, connectors and the large fuse next to the IMA.
