Faulty electrical ground repair - Insight Central: Honda Insight Forum
Old 12-01-2012, 12:47 AM   #1 (permalink)
Gadget01's Avatar
Default Faulty electrical ground repair
While under the car doing an oil change, I found this funky ground wire:
Upon further inspection, I found another one, not quite as funky but not far off:
After removing the coolant fill reservoir:
Gadget01 is offline   Reply With Quote
Old 12-01-2012, 12:50 AM   #2 (permalink)
Gadget01's Avatar
The lower ground wire removed:
Mmmmm.... tasty..... This almost looks like sabotage:
Assembling replacement cable:
Old 12-01-2012, 01:08 AM   #3 (permalink)
Gadget01's Avatar
Old vs. new:
Installed:
The larger ground is 4 AWG and the smaller is 8 AWG. Why Honda arranged it this way I'm not certain. Rather than assume I know better than Honda engineers, I elected not to change the arrangement.
The 8 AWG is some random car-audio amplifier wire with soldered ring terminals and the 4 AWG Radaflex welding cable that I'm also using for my audio system amplifier power. It's from CableYard.com:
RADAFLEX® #4 AWG Black Welding Cable
these are the lugs:
https://www.cableyard.com/LENCO-Cabl...Hole_p_33.html
The 4 AWG cable crimps were made with a combination of a hammer and this:
https://www.cableyard.com/LENCO-Swedg-On-Tool_p_29.html
I think I will order some 8 AWG Radaflex to replace what I have now for the sake of consistency. For now, I'll just throw on some split-loom tubing and call it good.
