Yup, the 25mm are long enough to hide the original stud entirely within the spacer. Shorter spacers will cause the studs to stick out and interfere with the wheel.
The OEM front track is 56.5" and rear track is 52.2", a difference of 4.3". These spacers add 1" to each side so you're basically getting halfway there. These still make a dramatic difference in how the car follows highway grooves.
And that extra 25mm added does not make the tire interfere with the spats/skirt?
Rush
Tucson AZ
I thought the rear wheel narrow track was designed in for mileage purposes. Did your spacers hurt fuel economy any?
They are narrower to allow the body to taper more with good clearance to aero shields for the max in service size of that tyre spec. Having a known tyre size and being enthusiast we can manage those issues. Hell it might even have clearance for snow chains on the tyre envelopes.
If anything they would be better as the leading front wheel cleans the airflow for the rear and also wet roads water is moved for more of the rear tyres.
Ride the ridges (stay out of the ruts). A hypermiling technique that helps with the 'swaying', also protects against hydroplaning during heavy rain when the ruts fill up, particularly with beefed up tire air pressures.
..Bob
'01 Red CVT US #218, 160K, Bought May '12 with 145k & 47.4 lmpg
Best commutes: 84.6 mpg / 50 miles, 72.2 / 100 miles. My commute: http://veloroutes.org/r/91468
Best tank 708 miles, 51.2 lmpg & climbing
Warm air mod & Grill block, AbCaRed00
Simple grid charger, Jeff652
4 1/2 acres of sovereign U.S. territory
Anytime, Anwhere,Go Navy or don't go
