Freeway tire grooves swaying car - Insight Central: Honda Insight Forum
Old 12-01-2012, 12:03 PM   #1 (permalink)
Default Freeway tire grooves swaying car
Are other people having problems with the grooves making their car sway like your driving drunk? Maybe I need an alignment? I put on 300 miles yesterday from Seattle to Vancouver, Wa. It was terrible unless I drove in the fast lane. It looks to me the grooves are from the wear in the tire tracks. I also bumped my tire pressures up to 45psi. Its mostly 70mph also.
2000 Honda Insight
fuelsipper is offline   Reply With Quote
Old 12-01-2012, 12:40 PM   #2 (permalink)
aisbell's Avatar
This is standard Insight behavior with RE-92's installed.
Aloha,
Art Isbell
2000 Insight A/C #559
Old 12-01-2012, 01:19 PM   #3 (permalink)
Rear track width is the culprit. I used 1/8 in. spacers on the rear wheels to correct. It got rid of probably 90% of the "wiggle". Calif. is really bad with the rain "grooves".
Use: 320,000 mi. @ 57.8 LMPG
07 FIT "S"
(3K made, The prototype one?)
Old 12-01-2012, 05:50 PM   #4 (permalink)
I thought the rear wheel narrow track was designed in for mileage purposes. Did your spacers hurt fuel economy any?
fkertis is offline   Reply With Quote
Old 12-01-2012, 06:22 PM   #5 (permalink)
No (Aero) and No.
07 FIT "S"
Old 12-02-2012, 01:46 AM   #6 (permalink)
Well then thank you for the information. Looks like I have to find out about spacers. I did have some new RE-92's installed a few weeks back. Didn't notice it with the old RE-92's. Weird.
2000 Honda Insight
Old 12-02-2012, 02:37 AM   #7 (permalink)
eq1
eq1's Avatar
A friend of mine installed 1" spacers on the rears to get rid of the same thing you describe. He said it worked great... Freeway is terrible ~seattle to tacoma...
2000MT, CAN, ~168K miles
Old 12-02-2012, 07:00 PM   #8 (permalink)
Premium Member
Apparently this is also a problem with motor cycles. Pounding on the freeway essentially wears gutters. I have found that riding up on the shoulder of the gutter works pretty well, run just a little right of where 90% of the traffic goes.
2000 Insight, red 160k. "Tardis"
IMA battery replacement done at 97 K.
Milage: 65mpg on 80 mile commute summer, 55 in winter.
seabag is offline   Reply With Quote
Old 12-03-2012, 07:32 PM   #9 (permalink)
You can run a maximum of 25mm spacers on the rear without having to modify the factory spats. I used Ichiba spacers:
Ichiba V2 25mm Wheel Spacer 4x100 56 1 Acura Honda | eBay
spets is offline   Reply With Quote
Old 12-03-2012, 08:06 PM   #10 (permalink)
Spets, how does this work? the original nut hide completely in the spacer? Studs are not to long?
How many milimiters we need to align with the front?&
